MTX 5
#2777
Stiffer - Decreased Rear Chassis Roll, Decreased Rear Traction, Increased On Power Steering (May Cause Oversteer), Quicker Steering Response in High Speed Chicanes
#2778
THANK YOU MUGEN??
Inconsistent steering, off centered thrust bearing holders, banana chassis, stripped gears,.yeah thank you mugen for leaving it to the customer to figure it out.some of us must be sponsored drivers and they never have issues with their cars or the corners
#2780
#2782
I have seen lots of guys using HUDY, that are very nice.
I use a mugen I find it very good too.
A lot of us use a single 4 cell LIPO that way only on battery to charge not two.
Main thing to watch out for is make sure the type you get has a narrow wheel and a small diameter. As I have found the thunder tiger type is too wide and to big to get in the hole cutout in the chassis.
Steve H
Steve H
#2783
Oh sorry Greg, our track has a few bumps but is pretty much smooth for the most part. But as stated by the doctor , a thinner rear sway bar allows the car to roll a bit more creating more rear traction. I tried it because I found the new chassis more rigid than the original so the car relies More on the suspension. The 2.2 feels great.
#2784
#2785
#2786
Looking for a good easy to drive setup for a medium sized track with some open and some tight sections. Are stock 200K/50K diff oils too thick for tighter tracks? Looking for some things to try, car seems edgy with stock setup.
#2788
[QUOTE=Dustin;12120560]Looking for a good easy to drive setup for a medium sized track with some open and some tight sections. Are stock 200K/50K diff oils too thick for tighter tracks? Looking for some things to try, car seems edgy with stock setup.[/
Oils are fine. Try a small sway bay in the rear . What are the issues that your having?
