Kyosho FW-05R
#3766
Re: New 3racing RR parts
Originally posted by NiMo
Whether you like 3racing or not (some parts are good) I think you'll like this one.
quick change centre bulk
Also coming are SSG deck and towers
BTW::: haven't posted but great thread, thanks for sharing the info, it's been a great help.
havy
#3768
Originally posted by Marcos.J
Hey NiMo my RR conversion its on its way do you have any tips?
And get some 3x6mm bearings for the rear upper swing arms.
I found the car a little strange to drive with foam tyres, but it wasn't until I switched back to rubber that I found the reason, the RR conversion gives more front end grip.
Downside - it takes a lot longer to work on the car as the front gearbox bolts now have to be removed (can't with them all)
#3769
Super Moderator
Just watch you don't drop the chassis spacers (you'll see what I mean) I use a little grease to hold them in place.
#3771
They give you more steering and improve the responsiveness. The car isn't so lazy with the RRR hubs.
#3773
weight
guys, whats the weight of your fw-05R, mine is 1995 grams dont know if its to heavy or just the right weight
#3774
#3775
Super Moderator
Originally posted by roadrage
are these the .8 ring gears? does anyone have a part# and price of this item? thanx.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=5922425831
#3776
Re: weight
I have reduced mine to 1635g recently. However, I noticed reducing "rotational mass" is more beneficial in terms of performance. Try 1) Kfactory lightweight pinions 2)Five Star aluminium center shaft and 2 speed holder 3) kyosho lightened clutch bell. To reduce the weight dramatically, try using AAA batteries, save about 30+ grams. RR conversion kit another 18grams.
Rgds
#3777
Re: Re: weight
Originally posted by BundyMan
That's pretty heavy dude! On the Kyosho catalogue its listed as 1780g without bodyshell and transponder.
If you want to make the car race ready at around 1725 grams, the car should weight about 1600 grams without shell, without fuel and without PT.
#3778
Hi!
My FW-05S with RR-Conversion (therefore I call it "FW-05RS") weights 1712 grams including RC-components, personal transponder (by the way, it weights only 8 grams - the akku-driven transponder weights 25 grams) but without body-shell and wothout fuel. My "Opel/Vauxhall-Astra"-body is another 103 grams.
=> Race-Ready without fuel: 1815 grams.
I am using five AAA-batteries, a small receiver (JR 310), rear carbon shock stay and the conversion. The R-Shocks and R-fueltank should increase weight on the other side.
Asking some V-One-Drivers i got about 80 grams penalty for the FW-05S. I will probably go for the Ti-Pillow-Balls and Ti-Screws to reduce weigth by about 40 grams.
Btw: Any suggestions where to get Ti-Screws one-by-one or a complete kit for the FW-05? Can't find a complete kit and i don't like to get it in packs of 10 from 7 different brands.
Any idea why Kyosho does not issue a tank that "goes around" or at least under the main cardan-shaft in front? The FW-04 had one (Part-No FW-77) but it has 100ml capacity.
Regards
Robert
Regards
Robert
#3779
#3780
Re: Re: Re: weight
Originally posted by InitialD
So you did all those things to save 145 grams?
Much annoying for me to watch others glued some coins on their kit because of underweight!! Is't D??? :
