Kyosho FW-05R
#3736
Its been a long time since i installed it
Cheers
Cheers
#3737
Originally posted by ziggy12345
bevel gears are different with a notch in one of them. I cant remember iof this goes in the front or not
Cheers
Cheers
#3740
Hi there
I wanted to know if anyone has installed two brake disk on their FW.... If yes..
Can you please let me know what parts were used or any mods. done...
I need to increase my stopping power since i have a very tight track and most of the turns are almost U turns.
cheers
ZiiZo
cheers
ZiiZo
#3741
Originally posted by uaerc
Hi there
cheers
ZiiZo
Hi there
cheers
ZiiZo
#3743
Re: Gearing
Originally posted by SRAD
Hello.....my question is....I see the new RR is on sale already overseas.
yes it is
I heard someone say that for the bigger tracks the car is undergeared. Is this true.
I have run my car at a track with the 45T and 26 pinion (27,28 available) where speeds are over 60mph, and it was still picking up speed.
Also does the RR come with the .08 gears. Thanks
Diff Rings - no. only the Kawahara is 0.8
#3744
New 3racing RR parts
Whether you like 3racing or not (some parts are good) I think you'll like this one.
quick change centre bulk
Also coming are SSG deck and towers
#3745
Once again, it is very easy to overgear the car with the Kawahara centre conversion, lots of engine heat and no revs. For me 21-26 is more than enough gearing on a looooooong straight!
#3747
QUOTE]Originally posted by Marcos.J
THANKS FOR THE TIP , 1.5 MM LESS IN THE FRONT. [/QUOTE]
yup...less in the front
along the bevel shaft/rod
Originally posted by BrainTeased
may i ask where the notch is located im also running the center conversion.
#3748
Hey guys, I was wondering if anyone has or knows anybody who has the manual for the ZT-1 conversion kit for the FW-05? I will be interested in buying it from whoever has it and wants to let it go... Thanks!!
#3749
Anyone have problem with the throttle servos? there seem to be a lot of em' burning up at our track. The guys experiencing this are using sanwa radios.
Nimo, have you got that problem?
Whether it is digital or analogue it burns. I personally have not burn one yet (hope not anyway) and I was previously using a futaba radio with futaba servos. Just changed to a sanwa radio M8. Any advise is much appreciated
#3750
Nobody has the manual for the ZT-1 conversion kit???
