Kyosho FW-05R
#4516
Clutch settings
What is the best setting for this car? Do you guys follow the manual settings? I had inserted shims before and after the clutch bell to minimize the free play (very little if any) and it seems to pack a little more punch.
Rgds
Rgds
#4517
Super Moderator
Re: Clutch settings
Rgds
Rgds
#4518
Yeah I used to have about .4 to .5 mm of freeplay but this friend mentioned that its better to have little or no free play at all. Just curious....and wonder if anyone else have similar setups.
Rgds
Rgds
#4519
I have mostly always set my end gap to .4mm on the FW-05R and now my V-One RRR.
#4520
Call me
Peter call me if it is possible.
Ken
Ken
#4521
I think you need to differentiate between the two terms as they are totally different.
#4522
Re: Clutch settings
Rgds
Rgds
#4523
Looking at it, kyosho is still using Centax-2. I am referring to the "clutch gap".
#4524
The tension of the centax spring is usually set on the track to see how the clutch response is required for a given clutch setup.
Wide open tracks usually require bigger clutch gap. Smaller tracks usually smaller clutch gap. Bigger clutch gap gives more agressive engagement and vice versa.
Usually if you go with smaller clutch gap, you may want to tighten the centax spring for the engine RPM to wind up a little to avoid the clutch bogging down when it engages.
When you add shims in the thrust bearing front, you're actually making the clutch gap closer. When you're putting shims inside the clutch in between the clutch nut and the bearing, you're making the end play less. Less end play will only give you more life to your thrust bearing and ensures that your clutch shoes do not rub on the clutchbell during idling which if it rubs may cause the engine to stall and which will make the clutch shoe wear higher or worse still meltdown !
#4525
End float on my car .4 - .5
Clutch gap? never thought about this one, I just set it so the car kicks out of the corner without bogging or without too higher revs.
Having the clutch bite too late can reduce the feel of applying the power on those sweeping corners, but having it bite too early can make it feel like an on/off switch.
#4526
Originally posted by InitialD
Bundyman is talking about end float (play of the clutchbell after installation) and you're talking about clutch gap (distance between clutch shoe and clutchbell).
#4527
possible steering fault ??
hey guys
i think i have a problem with my fw
the thing is, when i turn left, the left wheel has some slack where i can push it in and out further from where the steeirng plate is
(i know this is a bit hard to explain)
when i turn right, the right wheel is able to be pushed it more from where the steeirng plate is as well.
i notice that the links that adjust toe move more inwards towards the diff so the wheels arent turning equal frm left to right cause the inner wheels has this slop
can someone please help
thanks!~
thanks!~
#4528
Originally posted by NiMo
It's here already
I only ordered it 64 hours ago from Dimball.
It's here already
#4529
That's normal. It's called ackerman. The inside wheel has more throw because it has a smaller distance to travel around the corner.
