Xray NT1
#7201
thanks mrgsr:
I have a x-ray nt-1, I purchased it used but the racer who sold it to me sold the x-ray clutch system (gears inclulded) with the motor to another person.
I have serpent clutch and clutch bell with gears from my old serpent. My local hobby shop has been trying to get a the parts, and new clutch sytem for three weeks (as of today nothing) but they have failed. I wanted to race this week end. Guess i will see if they will work together.
Thanks you Phil for the motor, hopefully I will to use it one day
#7202
After years of carefully assembling kits I decided to install the adjustable pistons in the shocks when I built them. I'm sure buried somewhere is this 700+ page thread is a passionate discussion about those adjustable pistons. Could anyone give me the readers digest version?
#7204
So...
#7207
I need help understanding downstops vs droop. If I wanted to set up my NT1 per the stock setup sheet, it says to set front to 1 and rear to 4 on the droop blocks. Those numbers depend on the ride height and tire diameters right? If I set to 1 and 4 on the gauges, but had a 1 mm higher ride height than the stock set up, it would be completely different wouldn't it? Does everyone just measure how far the chassis rises before the wheels lift off? Do you do that every run? What good are the droop blocks then?
Thx
Thx
#7208
Thx
Thx
What might be confusing you is this: Normally we set our ride height by adjusting the tension on the springs. With any give size tire we normally tighten the spring to get more ride height and loosen to give less. When the tires get too small, you can tighten and tighten that spring but if the A-arm has reached its max downtravel you have to adjust the downstop (add droop) to get more ride height. If this second paragraph has confused you then just re-read the first paragraph and ignore this.
#7209
Hi guys,
When you hold to lock both rear tyres and turn the front tyres forward with some force, will the front able to rotate? Mine able to rotate with tickling sound. Ive got some handling issue, strip the car to check and everything's is normal.
#7211
Do you adjust the down stops every run as the tires get smaller though? I understand as the tires get smaller, you have to turn the shock collar to maintain the same ride height. When you do that, don't you have to adjust the down stop screws to maintain the same droop? I'm thinking of the uptravel value, but then I'm confused because the downstops make the arm stop at the same place every time, but the tire size makes the uptravel different. If I want to measure "2mm over ride height" droop, what good are the gauges other than to get both sides equal.
#7212
18Likes
