Like Tree10Likes
Xray NT1
Old 10-01-2012, 10:38 AM
  #6451
Originally Posted by 1evo RRR Driver View Post
Wonder why Martin didn't run the pro upperdeck!!!! Maybe trying to prove a point
you look clearly then you can notice the upper deck have modified to two piece for flex
kyosho malaysia is offline
Old 10-01-2012, 04:52 PM
  #6452
HHH
HHH's Avatar
Originally Posted by TAMAK View Post
Everyone ran Orcan GT3?
The three ran the GT3-S. Engines seemed to work very well on the track.
HHH is offline
Old 10-01-2012, 04:58 PM
  #6453
30Tooth's Avatar
Originally Posted by mrgsr View Post
look how narrow the chassis is on Dirks car
Maybe it's the new 2013 version chassis?
30Tooth is offline
Old 10-01-2012, 09:15 PM
  #6454
shiston's Avatar
And also Dirk Wischnewski's car looks to be running the new low profile shocks from the new electric T4
shiston is offline
Old 10-02-2012, 08:25 AM
  #6455
YLLIB's Avatar
Originally Posted by JamesHealey View Post
Also the rear blade setup costs a small fortune to upgrade to with no real benefit to the racer... The wire works fine!
I dont know if you really have tried it, for me it does help on bite tracks, especially when the car starts to traction roll. For us in the states it is helpful. The benifit is good if you have one in your box..
www.acornracingusa.com
products for serious on-road NITRO racers
YLLIB is offline
Old 10-02-2012, 08:28 AM
  #6456
YLLIB's Avatar
Originally Posted by Chaya View Post
Hi Guyz,
What other clutch spring would you recommend aside from the Orion brand. I just acquire an NT1 from a friend and have been struggling with the clutch set up. I have also tried the manual recommendation for setting it, but still having some problem.
TIA
a lot of the guys are using ACORN spring in there cars in the USA and the price is right.
you can find then @ www.acornracingusa.com
products for serious nitro on-road racers
YLLIB is offline
Old 10-02-2012, 02:53 PM
  #6457
zzorro's Avatar
Originally Posted by HHH View Post
Congratulations to Dirk Wischnewski (1st A Main), Alex Hapberg (TQ and 3rd A Main) and Martin Hudy (~5th A Main) at the Xray Asia Challenge held at RC Addict in Bangkok Thailand this past weekend.
Photos of Alex Hapberg's car below.
look nice car man
zzorro is offline
Old 10-08-2012, 01:57 AM
  #6458
Hi guys, I need some advices.
What pinion is good for 1st gear, if I use 24T for 2nd, when running stock 59/54 spurs.
Is 18T ok ? without causing any damage. or should I use 18/23 ?
Thank you
jbjb is offline
Old 10-08-2012, 01:58 AM
  #6459
jbjb is offline
Old 10-08-2012, 07:02 AM
  #6460
ToysRUsKid's Avatar
Trader Rating: 16 (100%+)
Thank you
most setups use 17/23 or 16/22,21. I'm not sure where you run but I haven't ever needed 18/24.
ToysRUsKid is offline
Old 10-08-2012, 08:52 AM
  #6461
YLLIB's Avatar
Thank you
depends on the engine your runnig or the performance of your engine.
products for serious on-road nitro racers
YLLIB is offline
Old 10-08-2012, 10:17 AM
  #6462
Thank you
For what I have tested a good starting point is a 17/23 with a 60/54 for most of the tracks, I havent really tried the 18/24 combination but I would think it would be too long,
rinolino is offline
Old 10-09-2012, 12:51 PM
  #6463
JamesHealey's Avatar
I run 18/58 and 22/54 goes well, very smooth and good top speed.
All though I may drop to 17/58 for more punch off the line.
JamesHealey is offline
  #6464
Old 10-10-2012, 03:10 AM
  #6465
Thank you everyone for your advices.
It's a long straight 1/8 track.
I'll try 17/23 and see if the top is good
jbjb is offline
