Xray NT1
#7189
The RX8 design update in "redrc" is very informative, with feedback from testing and component modeling. I am excited to see the 2014 NT1 when it becomes available.
#7190
Hello everyone!
I just purchased my first xray with the NT1 (I found a 2012 spec NIB) and I would like some help getting some springs to tune it. Using the stock springs as the baseline, I would like the part numbers for the two softer and two harder springs for the front and rear of the car
xray has LOTS of springs available and I'm not sure where to start looking
Thanks!
Thanks!
#7191
front spring on in kit spring is 338184 is 30.5 or medium violet the rear take a wild guess becuase it no longer comes up but would bet probably close to same color
so 338183 dark blue 28.5lb front 338286 dark blue 25lb rear 338185 light purple 33 lb front 338287 light purple 30lb rear
#7192
while your at it can you give me the next step lighter and heavier for the front and back?
#7193
#7194
Typically you will only run any of these combos, light purple frt blue rr or red frt light purple rr. sometimes i liked light purple frt and rr. easy car to set up i think you will be happy start with 600cst all around prolly with 3 hole frt and 2 hole rear pistons
#7195
i am hope'n someone can answer this question for me: --------------------------------------------------------------------------------
I am just asking will the serpent clutch system work on NT-1 2013 transmission?
#7196
It should. One of the local guys here fitted the nt1 clutch to his 747
#7198
Hello everyone..did a rebuild last night on my 2012 nt1 and noticed that the chassis is tweaked. Will the 2013(331103) chassi fit? or would i have to try n get the stock 2012 chassis (331102)
Thanks!
Thanks!
#7200
thanks mrgsr:
I have a x-ray nt-1, I purchased it used but the racer who sold it to me sold the x-ray clutch system (gears inclulded) with the motor to another person.
I have serpent clutch and clutch bell with gears from my old serpent. My local hobby shop has been trying to get a the parts, and new clutch sytem for three weeks (as of today nothing) but they have failed. I wanted to race this week end. Guess i will see if they will work together.
Thanks you Phil for the motor, hopefully I will to use it one day
18Likes
Does that make the clutch faster than the car?
