Like Tree6Likes
Old 12-24-2011, 06:18 PM   #6211
marvcat1's Avatar
Default Clutch spring
Has any one used the new conical clutch spring shims from xray? Is it worth the chance.
marvcat1 is offline   Reply With Quote
Old 12-24-2011, 06:52 PM   #6212
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Try posting on the xray/ rcamerica thread. The only people I could think of would be drew, ralph, and paul.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 12-29-2011, 05:53 AM   #6213
Hi all,
Does anyone here have a setup template for very low traction track? Our new track is on the roof top of the shopping mall. Very smooth surface but no grip at all even i'm using shore 32 for all tyre. My plan is to reduce the front diff oil from 80k to 60k and 40k for the back. Hope someone can share their experience if any.
shahie is offline   Reply With Quote
Old 12-29-2011, 01:54 PM   #6214
staikosn1's Avatar
Send a message via MSN to staikosn1
I think that your plan is to make the car as smoothest as you can,
I aggre with diff oils, and soft tyres, but you have also to make your centax softer-smoother, with softer spring, maybe white shoe, and try out more combinations!
Start with that, and we'll see!!
XRAY NT1 || RB T10 RC || FUTABA BLS || SANWA M11 ||
#FANATIX MODELS# #www.frt.gr#
staikosn1 is offline   Reply With Quote
Old 12-29-2011, 02:13 PM   #6215
Kyle Hazell's Avatar
Trader Rating: 17 (100%+)
Originally Posted by tonyhalandri View Post
I do not know what to say...servos are new just like the car..someone told me that I must change the receiver...also new
I had the same problem, out of the blue after running the car for quite a few race meetings, would just go into fail safe at random times.
Did some research and read a bit about thermal problems with the Futaba receivers.
Went through the whole process of elimination, servos, different reciever (twice), different battery pack, different lipo reg.... Also took the reciever out of the box as someone has also suggested.
Problem still stayed, went to the track for the next race meeting and then it did it 2 laps into open practice.... From that I concluded it was not a thermal issue from what I could see.
I eventually purchased a new 4PKS radio after a frustrating time and the problem has gone away.
Bit strange but it is what it is.....
ARC R8 RB - Blitz Kronos Tyres - Futaba
Kyle Hazell is offline   Reply With Quote
Old 12-29-2011, 03:34 PM   #6216
piper48
Guest
Posts: n/a
Default radio interference
I'll just share what I encountered. I run the 4PKS with the 603FS RX and Savox servos, had some glitching issues too. The Savox servo wires are really long so I stuffed them along with the power wire running from RX pack, into the RX box. With all those wires sitting on top of RX caused some interference. I shortened all the wires running into RX box and problem went away. Also check to see if your RX pack has plenty of juice. Low voltage on the pack can also seem like your systems glitching. This is just my experience and hope it helps any.
Old 12-29-2011, 07:20 PM   #6217
StewartFan20's Avatar
Default Savox Servos
Hello,
I see in this forum that some people are using Savox servos. Is there anything special that needs to be done to get them to fit? I'm not using any spacers and I am not using the grommets that come with the servos, Ive put some KO grommets on the servo, they are a little smaller. I can get the servo arm to miss the front layshaft, but I cannot get the servo arm to clear the radio tray. I've tried the Hudy servo arm and the arm clears the tray, but the link does not.
Has anyone else had issues with installing the Savox servos? If so, how did you solve it?
Thanks in advance.
Devil Dog Racing | HobbyTown USA (Kansas City,North) | Fastlane Raceway | Matrix Tires
Someday, I hope to be the man my dog thinks I am.
StewartFan20 is offline   Reply With Quote
Old 12-30-2011, 06:36 AM   #6218
Thanks guys for all the information...I am thinking first of all to purchase a life battery to eliminate the low voltage thought(I am running Nimh) and my servos are the rsx series as I mentioned...
I am also planning to change the sevros mode to normal from BLS digital through my 4pks menu.I read on 4pks manual that the BLS mode is only reccomended when using BLS futaba sevros..
Mtx6,Reds WCS,Protoform,kopropo,contact tires.
tonyhalandri is offline   Reply With Quote
Old 12-30-2011, 08:35 AM   #6219
djiewie's Avatar
Originally Posted by StewartFan20 View Post
Hello,
Thanks in advance.
i`ve bent the xray arm a little, used a heat gun.
hope this helps you.
djiewie is offline   Reply With Quote
Old 12-30-2011, 11:44 PM   #6220
piper48
Guest
Posts: n/a
Hello,
Thanks in advance.
I wish I could tell you why my Savox SC-1258 fits. I've got an older NT1 which I believe is the first production model. I bought it used and the previous owner ran a Futaba BLS series servo so the car came with 25t Futaba servo arm but I'm not sure if it's an XRAY brand.
I rebuilt the car per manual using spacers for a Futaba servo and used the Savox metal grommets, cap screw, and held it together with HPI 3mm lock nuts. As for the servo arm, you could try an Associated arm to see if it works. Hope that helps.
Old 01-01-2012, 07:53 AM   #6221
Thanks for the ideas.
I did notice something, the car I got is the 2010 WC edition and a friend of mine has an earlier version, maybe the first or second year they were out. The radio tray on the WC edition is narrower and the steering servo is closer to the center, which would explain why I don't have any shims and don't have much clearance.
Old 01-04-2012, 02:44 PM   #6222
Anyone know when xray is going to come out with a new sedan?
brettoakland is offline   Reply With Quote
Old 01-04-2012, 04:16 PM   #6223
bfong13's Avatar
I would venture to guess that XRAY will release a new nitro sedan right before or right after the 2012 200mm Worlds later this year.
bfong13 is offline   Reply With Quote
Old 01-04-2012, 04:17 PM   #6224
NikoRacing's Avatar
The toyfair in Nurnberg is yet to come (first week of february)..and Hudy should coming out with a NT2 or a 2012 specs version....but no more is known ....
NICOLA PEZZOTTI - italian F1 cat. driver - Serpent 747 - HIPEX exhaust system - HOTRACE tyres - SANWA M11X
NikoRacing is offline   Reply With Quote
Old 01-08-2012, 09:43 AM   #6225
Condor Speed's Avatar
Default Clutch Bell
Hello, I ran my Nt1 all season last year with the high dynamic clutch,,,The clutch still works very good but when do you know if the the clutch bell needs to be replace??
Top photon EX 13.5 Trinity D4, Lrp Flow Works R1 Lipo
Top Photon EX 25.5 USVTA Novak Fanton Lipo
Xray NT1 Picco
Desoto Racing
RC Target
Condor Speed is offline   Reply With Quote
