Like Tree7Likes
Old 02-13-2011, 06:13 AM   #5821
kickass's Avatar
Default CSO Break Dick
Can some one tell me if this CSO HARDCOATED BREAK DICK (as found on CSO web site) will make my car faster or just more desirable ???? Please only honest answer as I don't want to throw away money fornuffing - OMG.
"KicKass "OS" Racing Engines" "capricornrc.com.au"
"RC Arena" Home of "Maxima Fuel"
kickass is offline   Reply With Quote
Old 02-13-2011, 08:34 AM   #5822
SOLOARTIST 702's Avatar
Send a message via AIM to SOLOARTIST 702
more desirable
RC AMERICA / XRAY / HUDY/ MATRIX TIRES /KOPROPO / ORCAN GT3 /RED CUP RACING MEMBER / SPEEWORLD RACEWAY/ A+ performance parts /IVE SEEN THE XRAY TEAM DRIVE SO I GOT XRAY CARS / better to keep up than to catch up
WILLIAM PENDERGRASS
SOLOARTIST 702 is offline   Reply With Quote
Old 02-13-2011, 09:46 AM   #5823
Osiris 75's Avatar
Trader Rating: 17 (100%+)
Originally Posted by SOLOARTIST 702 View Post
more desirable
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 02-13-2011, 08:14 PM   #5824
tl2111's Avatar
Trader Rating: 21 (100%+)
Send a message via MSN to tl2111
is a Aluminum disc and will wears out but does give good braking.
tl2111 is offline   Reply With Quote
Old 02-16-2011, 02:45 PM   #5825
NikoRacing's Avatar
Default 3Racing for NT1
Hi to all!!
I just want to known if any of you tried the Titanium Center shaft (xn1-09) and Titanium 2nd shoe holder (xn1-10) for NT1 and how are them?
Any problem using this options? Now I'm using standard Xray's holder and optional spring steel hollow center shaft.
I'm always interested on decreasing the transmission weight but don't want to compromise the rielability
thanks to all
NICOLA PEZZOTTI - italian F1 cat. driver - Serpent 747 - HIPEX exhaust system - HOTRACE tyres - SANWA M11X
NikoRacing is offline   Reply With Quote
Old 02-16-2011, 03:01 PM   #5826
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Originally Posted by NikoRacing View Post
Hi to all!!
thanks to all
I have been using the titanium shoe holder for a few months now... Never had any problems of skipping 2nd gear or gear strip.
The titanium shoe is actually almost half the weight of the original one. And the wear is almost non-existent because cylinders instead of balls are used...
I don't know if the middle shaft of 3racing is lighter... And I dont think it would present a problem since the xray drivetrain uses pins instead of setscrews/adapters...
If you do get it, let us know if there is any difference in weight between them...
Hope this helps.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 02-16-2011, 03:18 PM   #5827
NikoRacing's Avatar
Hope this helps.
Ok thanks for the reply!
About the shaft..I think it should be lighter than the Xray's option one because the 3Racing Ti-shaft is hollow too but it's made by a lighter material...
..so if 1+1=2 it has to be lighter!
I had doubts on it since I've ever seen hollow steel shafts or not-hollow titanium shafts... and seing an "hollow Ti shaft" is uncommon
Old 02-16-2011, 04:01 PM   #5828
Actualy the Xray hollow 2 speed shaft and hollow middle shaft is lighter than the 3-racing and CSO shafts, from memory its 3g on the middle shaft and about 5 on the 2 speed shaft.
This is probbably due to the walls are thinner in the Xray then 3-racing and CSO
chovden is offline   Reply With Quote
Old 02-16-2011, 06:28 PM   #5829
Osiris 75's Avatar
I've tried the 3 Racing stuff and the quality is no where near the quality of Xray and CSO. In my opinion 3 racing parts will fail at the wrong time. I even used them when I was running Mugen and had the same experience.
Chris Kemper
Old 02-17-2011, 05:39 PM   #5830
kmichael's Avatar
+1 stick with xray if you can, the quality is best,you get what you pay for
kmichael is offline   Reply With Quote
Old 02-17-2011, 05:48 PM   #5831
JLock's Avatar
Got an Xray NT1R and I don't know why anyone would use non-Xray aftermarket parts on it. When I make my minor upgrades, it will definitely by OEM Xray parts. Xray products have the best fit/finish and quality upgrade parts on the market.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 02-20-2011, 07:18 AM   #5832
hey guys what do you reckon that the nt1-11 will e like compared to the nt1 wc car.
im looking in the next few days to buy a kit and cant decided between he 733
orthe nt1 i know every one wll say the nt1 here but the questern is shoud i wait for the -11 to arrive or gt the wc edition know
rufazz is offline   Reply With Quote
Old 02-20-2011, 07:37 AM   #5833
D-nicest's Avatar
Other than having the new 2011 chassis with the inserts, I doubt the 2011 will include as many hop ups as the WC edition. Thats if there actually is a 2011 car. IMO Get a WC while they're still available, best bang for your buck
Diatta Collymore [email protected]([email protected])(www.fordhamhobbies.com) (Wallacemotorsports.net) Fordham Hobbies, Wallace Motorsports, WRC Racing, Hot Race Tyres, Ielasi Tuned Engines, VP Power Master fuel, KO Propo America, Paint By Mikey Mike
D-nicest is offline   Reply With Quote
Old 02-20-2011, 07:55 AM   #5834
NikoRacing's Avatar
Default xray options and ALU 2speed 20t belt pulley tech-tip
What you say it's true but there are some parts that xray doesn't make. I'm talking about composite differential gears for example or different brake pads. Or if you see many of the xray (but also other brands) drivers use Sirio clutches because them are simply better or for they prefer them to the original one.
I'm looking for some titanium parts and I'm obliged to look at non-xray parts because the factory does not work on this material.
I've already heard about the low quality of the 3Racing titanium but as Riketsu said the shoe older hasn't a particular wear and so I think it's worth to try it.
Yesterday I tried out the new aluminium 2-speed belt pulley 20t (335910) and the best tip I can give you it's not to use it with soft-belts as them will trend to work all moved to the right. And finally you will race with a belt that run only for the half of his width on the diff pulley and the same on the brake pulley. Mounting a standard 5,5x177 reinforced belt will solve you all the problems.
I already wanted to revert to the standard belts due to the non-rielability of the soft ones (talking about the rear) and this is good for me
(sorry for my bad english...but I want to help you guys despite the "difficulty" of writing in another language)
bye
Old 02-20-2011, 05:03 PM   #5835
D-nicest's Avatar
When using the opt 20t alu pulley be sure to rotate your diff so that the guiding side walls are on opposite sides. That will keep the belt from wondering off and damaging the teeth...
