Like Tree6Likes
Old 12-26-2010, 02:39 AM   #5791
piper48
Guest
Posts: n/a
Default Difference between 20% and 30% nitro fuel
I'm in the process of cleaning and re-shimming my motor but I'm kinda debating wether or not to add more shims to run 30% nitro. I called our hobby store which also runs the race program and they informed me that majority of the guys are running 30% nitro. Whats the pro's and con's for running 30% nnitro fuel versus 20%? The motor I have is a Novarossi .12 Max I think. It uses a P6 turbo glow plug.
Old 12-26-2010, 04:13 AM   #5792
godzukihop's Avatar
Trader Rating: 31 (100%+)
Shorter run time with 30% compared to 20%.
godzukihop is offline   Reply With Quote
Old 12-26-2010, 11:22 AM   #5793
el salvador's Avatar
Lightbulb
Lem, just run 20%.......That engine would probably even run fine on 16%, but the difference in price between 20 and 30% verses run time/power output would give the nod to sticking w/20%! especially since we're just "Parking Lot Racing"! You will not be "Short on Power!
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
Old 12-26-2010, 09:58 PM   #5794
piper48
Guest
Posts: n/a
Thanks Lynn. Makes sense to run 20% since the motor is already shimmed for it. I ran into Franko today and he kinda gave me the nitro 101 today so my question was answered.
What about fuel brand? Are they all pretty much the same?
Old 12-26-2010, 10:18 PM   #5795
asw7576's Avatar
Agreed.
Engine temp will increase too.
piper48 : the most expensive fuel is runnertime. ( I assume the most expensive = the best ).
I use runnertime and o'donnel.
Old 01-02-2011, 08:25 PM   #5796
bfong13's Avatar
Trader Rating: 17 (100%+)
bfong13 is offline   Reply With Quote
Old 01-17-2011, 02:28 PM   #5797
Can only .12 motors fit in an NT1?
What's the fastest motor that can fit the NT1 and what kind of speeds would i be looking at?
i'm looking more for a pure speed parking lot basher then a track car.
thanks.
jude26 is offline   Reply With Quote
Old 01-22-2011, 04:31 AM   #5798
thanks.
O.S. 18TZ(P) fits right in
jbjb is offline   Reply With Quote
Old 01-22-2011, 10:16 PM   #5799
why would you want to install bigger engine????
Narra is offline   Reply With Quote
Old 01-23-2011, 12:34 AM   #5800
Originally Posted by asw7576 View Post
Agreed.
technically the higher the nitro content the cooler the engine should run. But this also depends on tune, oil content. Sometimes high oil content fuels will make an engine run hotter.
If you go from 16% to 25% in many cases you will be faster and will run cooler.
TomB is offline   Reply With Quote
Old 01-26-2011, 08:27 AM   #5801
18TZ will give you same power as mod.12, cost a lot less and last longer.
I use on my 220mm NT1
Old 02-03-2011, 03:37 AM   #5802
KMW
KMW's Avatar
Originally Posted by kerb View Post
Any news of the NT1 2011 ?
NT1 2011 Specs
KMW is offline   Reply With Quote
Old 02-03-2011, 03:41 AM   #5803
nice chassis idea,i wouldnt mind if xray does the same style pulleys as they have with the 1/8 car
ARC R10/2015 - HOBBYWING - PROAMPS - ORCA
BRCCC
elche_83 is offline   Reply With Quote
Old 02-03-2011, 11:34 AM   #5804
JLock's Avatar
No, this is not a correct statement. The higher the nitro content, the hotter your engine will run. Your statement has been a bad misnomer that has been floating around the nitro r/c world for years. If you don't believe me, tune your engine to 16% nitro, run it for 5 minutes and take a temp. Then, do the same thing with higher nitro content fuels, not changing the setting, then take a temp after the same 5 minute run. The temps will be higher due to the higher detonation points of the various nitro percentages.
Texas 5
It's not what you know; it's what you can prove.
The only thing that is for sure is that nothing is for sure!!!
The needs of the many outweigh the needs of the few, or the one.
There are 2 things in life that are infinite: the universe and stupidity.
JLock is offline   Reply With Quote
Old 02-03-2011, 01:55 PM   #5805
bvoltz's Avatar
Trader Rating: 44 (100%+)
Originally Posted by JLock View Post
No, this is not a correct statement. The higher the nitro content, the hotter your engine will run. Your statement has been a bad disnomer that has been floating around the nitro r/c world for years. If you don't believe me, tune your engine to 16% nitro, run it for 5 minutes and take a temp. Then, do the same thing with higher nitro content fuels, not changing the setting, then take a temp after the same 5 minute run. The temps will be higher due to the higher detonation points of the various nitro percentages.
bvoltz is offline   Reply With Quote
