Like Tree18Likes
Xray NT1
Old 12-21-2012 | 08:48 AM
  #6571
YLLIB's Avatar
The 2012 chassis is milled out a little different in the back area in the center opening and the 2012 also is milled at the engine, if I remember. But they work no matter what.
www.acornracingusa.com
products for serious "NITRO" on-road racers
YLLIB is offline
Old 12-21-2012 | 10:40 AM
  #6572
esckalayd's Avatar
Billy is right, the 12 chassis is milled differently around the engine, but both chassis are interchangeable.
esckalayd is offline
Old 12-22-2012 | 05:38 PM
  #6573
YLLIB's Avatar
Hello everyone, The SPEEDWORLD RACEWAY & ACORN RACING USA Family would like to wish you and your family a HAPPY and SAFE HOLIDAYS.
WWW.ACORNRACINGUSA.COM
PRODUCTS FOR SERIOUS "NITRO" ON-ROAD RACERS
YLLIB is offline
Old 12-23-2012 | 09:25 AM
  #6574
Suspended
Happy holidays
danohio is offline
Old 12-23-2012 | 07:17 PM
  #6575
s10dude's Avatar
Merry Christmas to All ...........
s10dude is offline
Old 12-28-2012 | 07:12 AM
  #6576
Rhyswilldo's Avatar
Anybody know if there are any big/noticable differences in motor performance when you run a exgaust gas cooler on the pressure hose??
Looking at many pics form the euros and worlds it seems to be 50/50 with people runnung them or not.. I have also seen fuel coolers on the fuel line to the motor, how much difference could it make??
Rhyswilldo is offline
Old 12-28-2012 | 07:29 AM
  #6577
doctormtx5's Avatar
In a short description it just made the tune more consistent threw out the main, actually started running better at the end of the main then the beginning. So it will help to eliminate heat from the exhaust gas that goes into the fuel tank, lowering the temperature of the fuel and increasing run time.
doctormtx5 is offline
Old 12-28-2012 | 05:41 PM
  #6578
Default Build Question
Hey guys, for the pro kit page 19 step 3, are the 2x3 silocone o-rings (972030) used? There not in my bag.
thanks.
triple7s is offline
Old 12-29-2012 | 06:11 AM
  #6579
s10dude's Avatar
contact where you bought kit and ask.......
s10dude is offline
Old 12-29-2012 | 07:09 AM
  #6580
HHH's Avatar
HHH
thanks.
In the last WC kit and latest Pro kit I built, the kits only come with o-rings for the aluminum one o-ring (high performance) configuration. If you want to build the composite or 2 o-ring alu configuration, you need to buy extra o-rings separately.
IMO, having tried all configurations, the one o-ring works best and lasts much longer than the instructions suggest. The instructions make it sound like the 1 o-ring configuration will not make a 45 min main, but this is not the case. They last months for me.
HHH is offline
Old 12-29-2012 | 05:43 PM
  #6581
Are you saying to use the aluminum "spacer" looking things instead of the silicone o-rings? Excuse my ignorance as I'm new to TC's. The manual and supplimental sheets with the kit only refer to silicone rings, unless I missed it.
Thanks for the help.
triple7s is offline
Old 12-29-2012 | 08:58 PM
  #6582
HHH's Avatar
HHH
No, use the composite spacers (one thick plus one thin) and one silicon o-ring. Aluminum refers to the aluminum shock bodies. There should be a supplemental instruction sheet (in addition to the instruction manual) that shows how to build the aluminum shock bodies.
The instructions are also here
http://www.teamxray.com/teamxray/sho...p?file_id=3999
HHH is offline
Old 01-03-2013 | 08:43 AM
  #6583
ogreasurada's Avatar
Cant wait...
ogreasurada is offline
  #6584
repost........
Old 01-04-2013 | 11:37 PM
  #6585
Bundy_Bear's Avatar
Think a few people thought a replacement car might have been on the cards for 2013, but if its not broke why replace it.
Will be interested to see what is included in 2013 kit, I would like to see them make a change to the chassis for engine movement on the bottom.
Bundy_Bear is offline
