Like Tree18Likes
Xray NT1
Old 07-20-2010 | 12:00 PM
  #5491
Q-B0R0 B0MBER's Avatar
Default BRAKE DISKS AND BRAKE PADS???????????????
WHAT BRAKE PADS BESIDES THE X RAY STOCK PADS ARE GOOD ,I SEEN THE CARBON FIBRE ONES BY KM ARE THEY ANY GOOD?
Q-B0R0 B0MBER is offline
Old 07-20-2010 | 02:50 PM
  #5492
RC MARKET's Avatar
KM in lower speed braking not smooth .
XRAY STD ,Kyosho or Mugen !
RC MARKET is offline
Old 07-20-2010 | 04:01 PM
  #5493
NikoRacing's Avatar
I also think that KM brakes are too violent..
Now I'm using the Capricorn brake set and I like it very much. It's almost impossible to lock the wheels when braking and this is very very positive.
NikoRacing is offline
Old 07-20-2010 | 06:54 PM
  #5494
ToysRUsKid's Avatar
Originally Posted by RC MARKET
KM Brake pads in low speed too much brake not so good !
i'm used STD keep change new for race .
YOu can adjust the brakes to not grab so hard many ways. replacing pads is too expensive and you get brake fade in long mains.
ToysRUsKid is offline
Old 07-20-2010 | 10:51 PM
  #5495
Alex Siddique's Avatar
can you please post the part number you used to convert it .
thanks
Alex Siddique is offline
Old 07-21-2010 | 12:01 PM
  #5496
NikoRacing's Avatar
thanks
There is a complete set composed by pads, ferodos and 2 springs...(and I think that also the Cap brake disc help a lot the braking)
The set has this code: CAP-510
http://www.capricornrc.com/os_capric...62&language=en
Old 07-21-2010 | 03:34 PM
  #5497
DS Motorsport's Avatar
I really like the mugen yellow teflon pads with some springs in between the pads.
For my own brake setup I used the Serpent 733 springs and bushes combined with a milled down Xceed disk and some custom carbon brake pad's to make everything fit.
This setup provides very aggressive and responsive braking from the first lap without fading or locking the wheels.
The second best option would be the Capricorn pads with the Capricorn disk. This makes for a very smooth braking system, a bit too smooth for my liking under hard braking. With the mugen pads I'm able to brake later.
I will use the Capricorn pads at our next round of nationals where you actually want smooth braking.
DS Motorsport is offline
Old 07-21-2010 | 03:50 PM
  #5498
Boys i am looking to reduce about 60 - 80 gram from the roller ? any advice on what parts will give me max saving ?
I would start out with this set:
http://www.capricornrc.com/os_capric...79&language=en
This combined with replacing all the steel pivot balls to aluminium ones will get you close to the 60-80 grams you are looking for.
If there is still budget left I would suggest replacing all the screws except the ones in the chassisplate for Ti ones.
If you want to save weight work in the following order:
1) Everything from the driveline and suspension, driveline gives you more acceleration, suspension more overall traction.
2) Get all the weight out of the highest points of the car, for instance the bodyshell. Most weigh around 120 grams, mine weighs in at 98 grams.
3) Outside to inside, getting rid of weight outside the wheelbase of the car will help it rotate better. Again the bodyshell or front bumper.
As you can see I would never advice someone with starting to save weight by switching to Lipo or Life. This will actually worsen performance.
If you want to switch to Lipo or Life get the brass plate as well, now you will lower the CG thus increasing corner speed.
Old 07-21-2010 | 05:59 PM
  #5499
do any of you have any feedback about the using of the xray kevlar belts on the nt1's drivetrain?
i'm looking forward to use them but i have my doubts about the performance and durability.
thanx
mc_chofo is offline
Old 07-22-2010 | 01:37 AM
  #5500
can somone tell me if these come with aluminium shock bodies..
http://www.amainhobbies.com/product_...orber-Set-2-T2
yes it clearly stats in the description it does.. but amainhobbies is telling me they come with plastic.
here is the thread; http://forums.amainhobbies.com/index.php?topic=3236.0
LiL_JaSoN is offline
Old 07-22-2010 | 03:52 AM
  #5501
ttso's Avatar
DS, I think you need.... cleanup a bit....
Nice milled down disc, really nice
ttso is offline
Old 07-23-2010 | 05:27 AM
  #5502
hm, just noticed mtx4 and nt1 rear belt is the same length!.
Old 07-23-2010 | 07:22 AM
  #5503
Seisick's Avatar
and 733 rear is the same as nt1 front
Seisick is offline
Old 07-26-2010 | 04:19 PM
  #5504
firecat's Avatar
does any one know if the exceed centax clutch will work on the x-ray.
firecat is offline
Old 07-26-2010 | 05:02 PM
  #5505
Yes it will
nitro ho is offline
