Like Tree7Likes
Old 06-08-2010, 08:30 PM   #5341
spurcheck's Avatar
Originally Posted by D-nicest View Post
With just the bearings installed and no shims does you clutch have play? and did you put shims behind the fly wheel collet? Pics would be helpful...
Thank you for your quick response to my dilema, though I am delayed in reading your post. Upon further review (by one of my other RC buds who is more detail oriented), we, or should I say he, figured it out. Two situations were found. First, I found in my pitbox some other flywheel/crankshaft collets that spaced the flywheel closer to the bearing. Second, I had positioned the clutch shoes improperly. The previous vehicle I ran the shoes (4 shoe system) were placed between the flywheel pins. This time we placed the shoes with one of the pins going thru the shoes and they seem to fit lower in the flywheel pocket.
Once again, thank you for taking the time to respond to my question.
The Punter or The Punt-ee,,,,,,,,,,,,,,,,,,,who you be??
No Apologies Racing, don't believe me, try me!!!!!
spurcheck is offline   Reply With Quote
Old 06-08-2010, 08:31 PM   #5342
spurcheck's Avatar
Originally Posted by PDX-Spike View Post
Just a thought. Is it possible that the end of the crankshaft has been shortened?
Yep, thought about that as a possibility, but found the answer, see my previous post.
Old 06-13-2010, 07:26 PM   #5343
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
Hi guys ,
I am running front 80 k and rear diff 60k . The issue is the car want to step out in fast direction change parts of the track . Steering feels not very responsive in the fast direction change areas . What would be the recommendation for diff oil change for front or rear . Track has good traction but has many hair pin like corners .
Thanking in advance
Alex Siddique
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 06-13-2010, 07:27 PM   #5344
KHoff7's Avatar
Good run Diatta and Paul!
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 06-14-2010, 01:24 AM   #5345
does x ray or some other after market company make optional brake pads
Old 06-14-2010, 02:11 AM   #5346
Alex, KM make pads for the NT1 and I would suggest your rear end breaking loose would be to do with your roll centres and/or rear arm position and/or too much quick weight transfer. Just some ideas.
CDS70 is offline   Reply With Quote
Old 06-14-2010, 03:49 AM   #5347
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
quick reply, try thicker shock oil in the front since its in quick transitions. It sounds like its jacking to much weight to fast. Oil change should fix that without changing to much else mid corner
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 06-14-2010, 03:55 AM   #5348
gtrmx's Avatar
Originally Posted by Alex Siddique View Post
Hi guys ,
Thanking in advance
Alex Siddique
Use a spool. You will be surprised how nice and predictable the car will drive.
Do not worry about steering. This car has plenty of it.
gtrmx is offline   Reply With Quote
Old 06-14-2010, 04:42 AM   #5349
thanks guys
Old 06-14-2010, 05:26 AM   #5350
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 06-14-2010, 05:05 PM   #5351
D-nicest's Avatar
Originally Posted by nitrobeast View Post
^^ Thanks guys, the comp was really tight. It was one of the better races I've been to in a while. Really had a good time...
Diatta Collymore [email protected]([email protected])(www.fordhamhobbies.com) (Wallacemotorsports.net) Fordham Hobbies, Wallace Motorsports, WRC Racing, Hot Race Tyres, Ielasi Tuned Engines, VP Power Master fuel, KO Propo America, Paint By Mikey Mike
D-nicest is offline   Reply With Quote
Old 06-14-2010, 05:09 PM   #5352
D-nicest's Avatar
Glad you were able to get everything squared away, you'll be really happy with the car
Old 06-15-2010, 05:39 PM   #5353
spurcheck's Avatar
Yes, you are 100% right, I was very happy with the car! The driver,,,,,well,,,,maybe not so much But for me, my first outting this year at Blue Diamond, new car and too much new stuff to list, I did well. Unfortunately, in practice I "popped" a motor, my only good motor (Murnan 353) That took the wind out of my sails and I had to use an old Ninja from several years ago. Made it thru the day though and that's what counts. Thanks for your responses again, really helped.
Old 06-15-2010, 05:45 PM   #5354
kmichael's Avatar
Are you still using 60wt in the rear when using a spool up front, or should you go to something like 80wt in rear with the spool up front???
kmichael is offline   Reply With Quote
Old 06-15-2010, 06:51 PM   #5355
TeamCarnage's Avatar
Trader Rating: 23 (100%+)
Great Racing! You gonna make the Byrons Race at Leisure Hours, Joliet IL? It would be worth another trip!
TeamCarnage is offline   Reply With Quote
