Like Tree6Likes
Old 03-24-2009, 05:33 AM   #3991
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by grub View Post
thanks m8....
i spent all last week stripping and rebuilding
and still had the worst day in 12 months ....
well be back
watch out patto!!!!!!!!!!!!!!!!
mate i had many days like that with a certain brand of car. but since the change, im having better days now. i know youll be back, but so will I , you got a month and a half till im back
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 03-24-2009, 05:36 AM   #3992
grub's Avatar
you beauty peice and quiet howray
This is my xray nt1!
There are many other xray nt1's like it, but this one is mine!
Without my xray nt1,I am nothing!
Without me, my xray nt1 is nothing!
pop corn anyone or maybe some fairy floss
grub is offline   Reply With Quote
Old 03-24-2009, 05:46 AM   #3993
All parts are there as per manual, even installed a brand new shoe set, still same problem.. it is really strange it worked perfectly for at least 9mths and suddenly jammed..
The only thing I have not tried is replacing the 2speed housing..
jelayne is offline   Reply With Quote
Old 03-24-2009, 12:55 PM   #3994
RC MARKET's Avatar
Originally Posted by DS Motorsport View Post
If i run diff's i run 80k in the front and 40k in the rear, sometimes 60k in the rear but that's only when the track is in perfect condition, like when there are big races. On small tracks however i use a solid axle in front.
Thanks !
RC MARKET is offline   Reply With Quote
Old 03-24-2009, 03:46 PM   #3995
grub's Avatar
try adjusting your screw cap set screws pins 983404 until you take all the slop out of the housing..also your shoe could be woren out as i think the problem in the centre hub 335570 has spun inside the housing and jamed up.
Old 03-24-2009, 06:16 PM   #3996
Hmm, I never really thought of the 335570 going bad, I will have to give it a second look, as it seems strong enough to outlast the transmission
Old 03-24-2009, 06:36 PM   #3997
Just stripped it down and it does not look worn, strange
Old 03-24-2009, 09:50 PM   #3998
grub's Avatar
my bad i ment 335540 gear box shoe
also check your spring arn't damaged and are not sticking open
i have seen the springs that get sticky and jamed open at times
i had a look if you have new springs for the 2 speed
drop them in and try it
let us know ho wit goes
Old 03-25-2009, 12:09 PM   #3999
asw7576's Avatar
Is this correct for NT1 ?
Front One Way / Gear Diff Pulley : 27 teeth
Front - Center Pulley : 19
Front - Left Side Pulley : 25 , 26 , 27
Rear - Left Side Pulley: 18
Rear - Center / Brake Pulley : 20
Rear - Gear Diff Pulley : 41
Old 03-25-2009, 01:11 PM   #4000
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
sounds right save for the 27 side pulley.. never seen that
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 03-26-2009, 05:33 PM   #4001
Thanks Grub I found the problem, it seems my rear tension was too much at neutral position when I changed to Kevlar belts.
Old 03-26-2009, 05:37 PM   #4002
Default 2 Speed Carrier - 335521
Guys it is normal for the light weight version to fit tightly on the shoe set, where it is barely moves when the shoes are completely closed ??
Old 03-27-2009, 05:36 PM   #4003
tony montana's Avatar
Trader Rating: 66 (100%+)
anyone have the 09 version yet? I like the car but it is alot of money
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 03-27-2009, 08:21 PM   #4004
Joey4875's Avatar
Alot of people have it now I have one and I'll be at the track Sunday (301)
Joey4875 is offline   Reply With Quote
Old 03-27-2009, 08:24 PM   #4005
Joey4875's Avatar
Whats the difference between the T2 009 front shock springs and the NT1 front springs besides the lenght
