Xray NT1
#6991
#6992
Are there any major differences between the high dynamic and reverse clutches?
As far as I can see the only difference is the pressure plate, flywheel and the way the fly weights are installed.
I have 2 high dynamic but no reverse and hear the reverse is much better, if all I need is the flywheel and pressure plate it would make things a lot cheaper since I have plenty of extra yellow and red shoes
#6993
#6995
Instead of saying it will not work, just try it. What harm is there? If you don't like it just put the 2mm shim at the back of the arm and your right back where you started. I tried it because some team drivers had it and also said try it and see if you like it and I did. I am telling Joe what I did because he saw a picture and asked. All of the people I saw run the car long in the back had the front of the car short.
What benefits did you get with this mod. godzikop
#6996
I tried this without the front short and it made the rear PLANTED. couldn`t get the car to turn the way it was. Still going to try higher rc in the rear to see what it brings since i have the 2009 car still. Maybe try the front short.
#7003
#7004
What's up? I recently noticed when I have my front wheels turned to the left there's something rubbing. There's no engine installed, car is in roller form. When I turn right it doesn't do it, I took off the side belt, turn left and when the tire gets about 1/2 of the full way around I feel a rub slowing it down and can't figure out where its from.
I changed every pulley, belt, front and rear arms, front and rear knuckles, every bearing to brand new ones (not just cleaned and put back in) and still can't figure it out.
It doesn't do it when I have the radio is on and turned left since my EPA will never need to go full lock, but it just bothers me and like my stuff 100%.
Any suggestions will be appreciated, anything I forgot to check? Regionals are tomorrow (9/28) and want it 100%.
Thanks in advance
Thanks in advance
#7005
Thanks in advance
Thanks in advance
1. Your axle could be binding. Check it has enough sideway clearance, an it doesn't bind around the joint or
2. The actual rim could be rubbing or binding (I got this with certain tire brands),
18Likes
