Like Tree18Likes
Xray NT1
Old 03-18-2009 | 05:43 AM
  #3961
DS Motorsport's Avatar
Originally Posted by RayJ
Have you run the car with the weights in it yet? I also used weights attached with servo tape, and the weights got chucked all over the track. Combine that with a little spilled fuel which dissolves the glue on the servo tape, and you have a mess on your hands.
I ran it last weekend for about 300 laps, including a race and all the weights where still in place, actually there where really hard to get off, had to pry them off with a screwdriver. But the weights i used are the one's we also use in motorsport, they will stick to a wheel with speeds op to 340 km/h
But it only was a temporarily solution because the chassis and the brass tray are still being hold at custom's. Once i know the exact weight needed i will make a brass weight which will be screwed in place.
Don't want to run the risk to be disqualified after a race win because i lost a 5 gram weight
DS Motorsport is offline
Old 03-18-2009 | 10:33 AM
  #3962
breez1090's Avatar
Originally Posted by RC MARKET
a while back somebody said they use this transponder holder how is it used???
breez1090 is offline
Old 03-18-2009 | 10:40 AM
  #3963
RC MARKET's Avatar
stay in upper deck
RC MARKET is offline
Old 03-18-2009 | 11:14 AM
  #3964
breez1090's Avatar
do you have a picture example??
Old 03-18-2009 | 11:17 AM
  #3965
RC MARKET's Avatar
XRAY web site had posted !
not miss your lap , because stay in servo maybe miss lap time
Thanks !
Old 03-18-2009 | 11:21 AM
  #3966
breez1090's Avatar
thanks
Old 03-19-2009 | 05:23 PM
  #3967
dht
What body recomended for the Nt1 IN A short track?
thanks
dht is offline
Old 03-19-2009 | 05:39 PM
  #3968
Try the protoform mazda 6 i found it great on short tracks here
mrgsr is online now
Old 03-19-2009 | 08:25 PM
  #3969
D-nicest's Avatar
thanks
You can't go wrong with the Stratus 3.1 from Protoform
D-nicest is offline
Old 03-19-2009 | 09:53 PM
  #3970
Osiris 75's Avatar
thanks
Also try the civic body.
Osiris 75 is offline
Old 03-20-2009 | 07:20 PM
  #3971
aussies1129's Avatar
Hi guys could anyone tell me if on your one way hub first gear that inside where all the pins are, check all the pins and see if there is a empty slot?
the reason why I asked is that my light weight bearing failed after 5 min run and I looked inside and notice a missing pin? so I put on the original but now have noticed that there is a pin missing in there also? is that the way they come do they come with 6 pins?
cheers
aussies1129 is offline
Old 03-21-2009 | 12:40 AM
  #3972
rcfoolz's Avatar
cheers
No empty slots......I have one that is like that, one missin slot... The reason this happens is that when you slide it onto the 2-speed shaft, you push it on and it will sometimes eject the pin. This happened to me while doing a rebuild and when I was done, I had this very thin pin....I saved it and put it in a bearing sleave that you get when you build the car. The next day at the track, my oneway failed and upon inspecting it, it was missing a pin. I took the pin out and inserted it into the slot. never had an issue agian.
rcfoolz is offline
Old 03-21-2009 | 03:23 AM
  #3973
excellant thats good to know, I cant believe they come out???
cheers mate
Old 03-21-2009 | 04:12 AM
  #3974
rcfoolz's Avatar
cheers mate
To prevent this from happening agian, always turn the gear while sliding it onto the 2 speed shaft.
rcfoolz is offline
Old 03-21-2009 | 04:52 AM
  #3975
thanks for the good advice will definately do from now on.
foolz would you know the pin size that goes in the bearing I might get a few spare just in case??
cheers
