Richey Modified Motors
#1142
kool
#1143
Originally posted by Motorman
loose the Gt pipe it is a tork pipe not an RPM pipe. Try an RD logics pipe. It will make more top end. KZ is huge as I understand it. Even an RTU mod runs out of revs there.
If you get the two piece pipe make it as short as you can get it by cutting the header
Ironically today was the race,. and luckily I was actually able to get a hold of the new RD Logics pipe... whoa! Not only did it give great low down response but also got me to end of the straight away... while also keeping my temps down. My MR-12 was burning up with some other pipes I tried (older RD pipe, Kyosho, and Collari). The motor did have awesome snap with the GT pipe so I may try that out at Revelation later. It looked like it stopped pulling at about the distance Rev's straight is, so it may actually work.
#1144
...it's the pipe. I ran the my RTU with the RD Logics pipe yesterday and part of today there and I wasn't running out of motor. The motor was awesome before it exploded (that happens sometimes when it runs WOT upside down for a while). Dennis, see your email for more details
#1145
Dang that sucks ChrisF! I don't even want to tell you about what happened to me in the main!
#1146
You can tell me Kevin
#1148
That's why I knew you could feel my pain Dennis
#1149
#1151
Location: Redford Mi. Trying to keep up with Tim Stamper
I heard he works with " skunks" .
#1152
woahhhhhh dennis, you were part of skunkworks? thats sweeeet.......
and yes, im kidding, im really not as stupid as i sound
#1153
He's a wild animal Vet............. ?
#1154
16% nitro and conical (turbo) plugs question.
This is a question that I've been trying to get some feedback for some time and would to ask you guys.
I'm using .12 engines with conical plugs (I hesitate to call them 'Turbo') with 16% nitro. I'm starting to do some tests with different plugs, but what puzzles me is about the difference of the Cold and Warm plugs of the same number (let's say a #5 cold and a #5 warm).
For our actual temperatures (5 - 10ºC air temp) I'm using a #5 warm and when temp raise will go to a #6, but my real question is: Cold or Warm? What differences are on those plugs and if are advantageous to keep Cold and Warm models of the same number (#5Cold,#5Warm,#6Cold and #6Warm)?
Dennis and others, what you think? on my 1/8 on road ever use #7Cold and #8Cold....
#1155
Re: 16% nitro and conical (turbo) plugs question.
