Kyosho V-ONE RRR Evo
#1531
Originally Posted by Trilordy.com
anyone?
Never heard of a spool for the rear on the rrr.
Front, see previous posts on this thread about K-factory ones.
#1532
Originally Posted by occ
For the rear or for the front?
#1533
Yes the rear, i want to get rid of the Diff, kyosho call it Rigid drive or something.
You could always try using the solid axle adapter that comes with the kit, but I'm not sure it would work or hold up. 3Racing makes an aluminum one: http://rc-mushroom.com/product_info....oducts_id=3806
#1534
This track is just minutes away from the Nation's Capital
RC Pro Series two-day race entry form
Can be submitted at the track on race day.
Capital Classic June 6th-10th
Factory drivers already registered. 160 max. entries. Don't miss this one!
#1536
SCREWS
Need your guy's opinions......
Is it worth changing the stock screws on my EVO WC to titanium hex type or alloy hex ones? I haven't built the car yet, so I'm contemplating if I should order some and also where to buy them. I know I read somewhere here or on the other V1RRR thread to just stick with stock screws for the motor/motor mount.
Appreciate any input you guys might have. Also I'm just going to put a diff in the front when I build the car due to layout of the track I will be racing on and also the other racers recommend the diff over the spool.
Thanks in advance.
Thanks in advance.
#1537
Thanks in advance.
Thanks in advance.
They are great and great service from Tony....
#1538
I built mine last week with hex head screws from Tony's Screws and am glad i did, the kit comes with phillips head screws that usually rounded off by the time they were even half way into the plastic.
heres a link to Tony's
https://www.tonysscrews.com/displayP...5&categoryId=2
#1539
Agree 100%. Get the hex screws.
#1540
SCREWS
Thanks for your responses. Will change and order the screw set from Tony. Regarding the issues with the motor mount, should I just stick with the stock screws or the one's that came with set from Tony would be fine or better than the stock ones?
#1541
#1542
Front Diff Setup
Originally Posted by rmdhawaii
I would agree. For tight, sharp and winding, a front diff would probably work out best.
Part numbers are in the manual.. for anyone wanting them:
VZ218 - Differential Joint
BS107 - Bezel shaft
VZ012 - Gear Set
cheerz..
#1543
I think he was referring to a standard diff just like in the rear of the car. The manual has a list of the parts you need to get to build one.
#1544
where can i find a website that has a lot of kyosho hop up parts , im looking for the steel pinion gears 1&2 every where i look they only have 1st gear please help thanks
#1545
