Kyosho V-ONE RRR Evo
#1516
hi all im new here and i want to start off with a question: I Ordered the kyosho VoneRRR EVO WC edition and i was wondering what all the Teeth counts are on all the Plastic Pullies. I want to upgrade them to ALU so if someone could tell me what they all are i can go ahead and order them! Thanks
#1517
Mid Shaft 18t
Side Belt Front 23t or 24t (23t requires 2mm split 24t requires 0mm split)
Side Belt Rear 18t
2 speed shaft 21t
Rear Diff 42
#1518
Originally Posted by wiggindude
I cant find a spool for my new kit. Does anyone know who has them in stock?
I dont care if its 3 racing, kyosho or K factory.. anything will do at this point.
thanks
thanks
#1519
thanks
thanks
#1520
thanks
thanks
http://www.km-rc.com/oscommerce/cata...701d3b71e6759b
#1521
Spool vs Oneway
ok.. so r most people running spools vs one ways on their rrr evo's? from what i have read it comes down to track type and driving style? can someone clarify if im way off with this here.. trying to get my cars braking dialed in...
tight, sharp and winding track - spool is better primarily due to 4w braking power but can bind the 4wd system through corners etc
long fast sweeping track - one way is best car will be 2wd on straights and 4wd out of corners, 2w rear braking only
both systems need proper tyre diameters must be set.
even as possible for spool..
larger rear and smaller front for one-way..
will be racing on a long but winding track, i would kinda like to leave my rrr with the one way setup and work on getting that dialed in, after practicing @ the track yesterday for the 1st time, i am finding the car (awesome but) hard to control at the end of straights when at high speed and braking hard into fast corners. should i be adjusting my driving style or trying a spool setup??
#1522
#1523
Originally Posted by JRRobiso
You can probably try running a diff up front.
#1524
where did you drive it?
#1525
Originally Posted by Sp Racer
Almost every Kyosho driver in Melbourne is using a spool on every track - the benefits of the spool outweigh the advantages of the one way IMO - specially when braking at the end of a long straight.
#1526
Also driver was start use Spool
#1527
hi i just recieved my VoneRRR EVO WCE but i was wanting a Spool for the rear and kyosho america has them on backorder, where else could i find one? 3rd party would be fine.
#1528
does anybody know part number for Swing Shaft of VZW219 Universal Swing Shaft?
#1530
