Like Tree100Likes
Mugen MBX7R
    Hide Wikipost
Old 04-11-2017, 02:45 PM   -   Wikipost
R/C Tech ForumsThread Wiki: Mugen MBX7R
Last edit by: E1 Diablo
Old 08-08-2016, 04:21 AM
  #2746
bash bros's Avatar
Originally Posted by mrosique
Is it true the 5th hole helps to drive easily? How the car reactions change in the steering ackerman positions?
Thanks in advance!
Check out Drake's ackermann video on youtube.
bash bros is offline
Old 08-08-2016, 07:24 AM
  #2747
mrosique's Avatar
Bash Bros, definitely the vdo is the answer
Thanks a lot!
mrosique is offline
Old 08-09-2016, 02:43 PM
  #2748
bash bros's Avatar
Originally Posted by john Mc
I run the hot bodies wing mount you just have to cut out the bottom support then bend it
in the bottom holes and they line right up. I heat it with a heat gun and it keeps its shape.
Yeah I decided to try it out, only took me about 5 minutes to dremel it and bend the bottom supports.
Although I like it it's not a huge upgrade over the stock mount imo it's still worth trying.
It's good for if you run a lexan wing. It is more flexible and if you crash it will absorb some of the impact and keep your lexan wing in relatively decent shape. But if it takes a good amount of abuse you're going to have to get the heat gun out and straighten it out at the end of the day.
Old 08-09-2016, 03:20 PM
  #2749
hi guys what type of bearings should in use in the stock clutch bell as I'm a little confused on which of shielded type . I'm currently using metal shielded at the moment.which last the longest and can stand the most heat.
TIM.L.BARNETT is offline
Old 08-09-2016, 04:46 PM
  #2750
Trader Rating: 22 (100%+)
Default Clutch
I currently own a nb48 and just bought a lutz clutch for it and I'm on the verge of switching over to the mbx7r and was wondering will that clutch work for the mbx? On the site it lists mugen style or tekno style, but it is 34mm flywheel. Any insight on this?
Also where is the cheapest place to buy one of these kits?
NoobRacer is offline
Old 08-09-2016, 05:06 PM
  #2751
bash bros's Avatar
It's a matter of preference. Metal shielded are fine especially if you run on astro they'll last a while compared to a dusty track.
The Lutz clutch will work, you'll probably need the mugen style bell though.
As far as kits, usually Tower is the cheapest but right now Amain or Absolute are probably the cheapest @ 549 plus the coupon codes
Old 08-09-2016, 06:47 PM
  #2752
Thank you thank you.
Where are the coupons? Or do you have to be a member on there to get the promos?
Old 08-09-2016, 07:02 PM
  #2753
BermyDomRepRC's Avatar
Trader Rating: 26 (100%+)
With Hot Bodies wing mount are you guys using ?
BermyDomRepRC is offline
Old 08-09-2016, 07:44 PM
  #2754
bash bros's Avatar
For Absolute Hobbyz you just need to register an email address, they have their monthly coupons up at the top of their page
Amain $20 off code is AUG2020
You'll want the +10mm mount, Part# HBS114415
Old 08-09-2016, 08:17 PM
  #2755
Thanks bud !
Old 08-09-2016, 09:03 PM
  #2756
STLNLST's Avatar
Trader Rating: 32 (100%+)
What are people using for a pillow ball tool?
STLNLST is offline
Old 08-09-2016, 10:49 PM
  #2757
tom1974's Avatar
Can I use HBS114415 in mugen tower???
tom1974 is offline
Old 08-10-2016, 12:35 AM
  #2758
I use the same one drake does. Works great.
https://www.amainhobbies.com/protek-...k-8202/p212258
rotor head33 is offline
Old 08-10-2016, 01:54 AM
  #2759
Trader Rating: 42 (100%+)
I have a used nitro buggy very nice if your interested
TRUGGYRACER1 is offline
Old 08-10-2016, 03:29 AM
  #2760
is there a chart for the front axle pills for toe and caster?
gt racing is offline
