Mugen MBX7R
#2762
Yes, that's the one you'll want to use. The lower mounting holes have a support brace in between them, all you have to do is cut that off and then bend the ends in slightly and it will line up with the mounting holes on the rear tower. Takes about 5 minutes with a dremel and a heat gun/hair dryer.
#2763
What all is needed to convert this nitro into the Eco?
Battery tray, center diff, radio box?
Is the chassis a must?
#2764
Yes. And motor mount.
#2765
the nitro chassis and the eco version are really 2 different chassis.
the center diff is indeed are the exact same place but you have to drill a bunch of holes to fit the parts like the lipo tray + the eco radio+servo tray. I did it with a M2C nitro chassis...
#2766
It's definitely better to just grab an Eco chasis from dollarhobbyz.com
#2769
Not blasphemy at all. Several people do it. Just requires some trimming here and there.
#2771
It also will but I must say I'm not a fan of proline bodies. You must have some pre painted ones for associated vehicles I'm assuming?
#2774
Won't know till ya try it.
