Mugen MBX7R
#2911
Where are you getting that from rotor? We have not gotten any word from mugen on a new kit. I think new parts are being tested but nothing drastic.. Truhe asked me for a weird bearing size last week in Vegas(6x16). It was something in his drive train for sure.. I really don't care, if a new car was offered to the team guys before the worlds, I would not drive it. Too risky, I'm building a new 7r for the worlds.. Mugen is very good at keeping secrets. Adam has been testing a lot in Vegas, and it's not anything new! He is the only one using that wing mount.
A local driver just signed with Mugen last month and they told him when they gave him his contract that he has to drive the newest car everytime it comes out for example he will have to start driving the mbx8 when it comes out after worlds.
Heard them tell him with my own to ears. Secret or no secret the team drivers just aren't supposed to say anything yet. In not a team driver so I don't mind lol
#2912
So I've been running the Mugen E-buggy for over a year now and I recently just started running nitro as well with a 7r. My Ebuggy is dialed. Super easy to drive, tons of grip, etc. The nitro buggy on the other hand seems very "busy". The harder I drive it the better it is but that's not my driving style, I'm more of a smooth driver. So I guess my question is can I get the nitro buggy to feel like the E-buggy? Currently running Adam's Base setup on the nitro buggy. Any input is appreciated 👍
His setup also runs max active caster on the front upper arms, this makes the car a little looser on power and in the middle of a corner, try lowering the front of the upper arms ( shock tower pill)
Also move the steering link forward on the Ackerman plate to settle the car down off center
Hope this helps
#2913
What setup do you run on your e buggy? I run my nitro and e buggy with the exact same setup and the feel identical minus the instant torque of the e buggy. I know Cole also runs his the same minus springs.
#2914
Adams " base " setup uses some pretty thin shock oil, try going up both front and rear
Hope this helps
Hope this helps
#2915
Hmm...maybe I'll try switching the pill setup to what I have in my E-buggy then. Setup is my own that I've developed over time but originally based off Adam's OCRC indoor setup actually
#2917
The graphite towers definitely soften the response up some. I run graphite towers in both of my cars pretty much full time.
With 6x1.3 pistons I absolutely love 37.5/32.5 with losi oils
#2919
Yeah 6x1.3 Kyosho pistons with 9.25 front spring and 10.25 rear spring. I have also been running the underdrive setup but I'm going to take it out and try it. My E-buggy has the 5x1.35 Mugen pistons with 37.5 oil front and rear and Kyosho springs. No underdrive no weight
#2920
The 7r is great out of the box. The center universals are a nice upgrade because it's less rolling resistance and one less set screw to back out. I also run 6 x 1.3mm shocks...
Great car out of the box. Proven car. Built like a brick crap house. No need to spend $$ on placebo upgrades.
#2921
^^^ agree. Here are the upgrades I'd like to see:
- Upgraded wing mount - (I don't have a problem with the current wing mount)
- Four shoe clutch (never tried - three shoe won a lot of races)
- center universals - mainly because it's two less set screws away from a DNF
- some awesome bearings (wish)
#2922
#2924
I'd be happy with bleeder shock caps
#2925
R/C Tech Elite Member
Trader Rating: 123 (100%+)
- 90* elbow coming out of the front of the tank for easier fuel line routing. (We know Drake has input)
- split center diff mount
- new pills for hinge pins allowing for more precise adjustments. wide, narrow, center / up, down, center.
-molded rear hubs WITH the bushings for top, middle, and lower hole as standard.
- center f/r universals as standard.
I know they are testing a one-piece wing mount, but not sure if it is the same height, just stronger. Or, if it puts the wing in a different location. I am fine with the current mount.
Can't really think of any other convenience upgrades. I am not an engineer, so there may be slight geometry changes to make also...
