Mugen MBX7R
#2599
Just like you, I've never had a loose car or car that pushed either?? Setup always dialed in 100% ...
Diff fluids depends on track conditions.
Typically I will run 7-5-3 with under drive in rear. Will use any combination of 7s, 5s and 3s in diffs and under-drive rear or normal diff depending on track and conditions.
#2600
It's the rear diff fluid and the under drive in the rear is compounding the problem.
With the standard gears in the car and 4k in the rear the throttle trigger will get touchy. It hasn't mattered what gear is in the rear with 3k, it's just about un drivable.
Try 7/7/5 with kit stock gears.
I start with 10/10/6 everywhere, standard ring&pinion.
#2601
Hardly up drivable with three in the rear. I run 5/7/3 on both loose and high grip tracks and it's perfect. Rotates beautifully around hairpins and turns on a dime elsewhere. Punching it to come out of a corner it squares up 10x faster than 6 or 5k
#2602
I pretty much run box stock set up, but have tested many things. I find with 3k in the rear it's more planted and predictable out of corners. With 5k it was just a little too twitchy for me, the back end would come around after the apex of the corner in some spots at my local track. I much prefer 3k in mine. Just to clarify, I run stock gearing and I have 30g of weight in the back
#2603
#2604
Go to 3* rear toe.cstock out the bix setup is 2.75*..Fast easy to do,you should have that pill insert. My son always runs 3*, we run the same setup everywhere! Pretty much box stock except for piston,oil,springs.. No weight either. Play with rear camber length.. Look at All of batlle's setups, he runs 3* all the time. Drake never does.. We always run 3-4k in the rear
