Team Associated RC8B3 Nitro Team Kit
#4126
Updated car has been released: https://www.associatedelectrics.com/.../RC8B3.2/Team/
Features
- New suspension arm design with inserts for flex adjustments
- Longer rear suspension arm length with narrow rear arm mounts
- New center bulkhead splits and has front/rear specific top halves to prevent brake misalignment
- Enclosed battery box for quick and easy battery removal
- Larger receiver box for better wire management
- One-piece graphite transponder and electronic switch mount
- Flex Control(r) radio tray has three different configurations for chassis flex adjustment
- New stiff shock bladder design improves jumping and handling performance
- Updated shock cap works for bladder or emulsion style shock setups
- Shorter and lower front bumper reduces drag and allows easier access to anti-roll bar screws
- I.F.M.A.R. approved rear wing
- 42T ring and 12T pinion gears on front and rear differentials for improved gear ratios
- Updated chassis with chamfered front edges to reduce drag
- Side guards are now threaded into the chassis from the top side of the car
- 90% parts compatibility with RC8B3.2e
#4128
46tv2 spur
I have the Rc8b3.1 what do I have to purchase in order for the 46tv2 to fit my center diff drives
#4129
Side by side the new VISION body for Nitro and Electric Team Associated 1/8 race buggy!
Designed and developed for the RC8B3.1 and perfectly compatible at 100% with the just released B3.2 version!!
>>> Visit our store to see all the amazing features of these hotness --> bittydesign.net/en/vision-ae-rc8b31
#4130
Can anyone point me in the direction of a quality GREASED set of bearings for the car. I cooked a diff pinion bearing and I’d like to ditch the oiled bearings.
#4134
Yeah TJ talked about that the other day on FB. Definitely a cool feature. Also I believe the new kit is going to come with greased bearings.
#4138
