Team Associated RC8B3 Nitro Team Kit
#4111
The next time I need to replace my arms I may try something. The new Tekno cars have a bushing that goes into the arm where the hinge pin goes though. I may try drilling the AE arms to accept those bushings and see if that will give a little more smoothness and consistency.
Never noticed that on the new teknos, pretty smart idea. Don't think there is enough meat on the current AE arms for that to be a viable solution though.
#4113
That's my concern too, but I think you only have to open up the arms from 4mm to 5mm. I have some of the bushings ordered so I'll see if it works or not.
#4114
Awesome. Let me know how it goes
#4115
I have not really noticed a difference set screwing the lower arms to the hinge pin on the 3.1, so I abandoned the practice there.
All my lower arms have been great out of the package, I lightly ream them and put them on. I have noticed I've needed to shim all the lowers close to 1mm. All the arms on the car slid back and forth between the suspension blocks. Yes, this was even with the plastic 1mm spacer up front. I thought I built the car wrong initially.
#4117
Awesome! Thanks for taking the time to post all that info. I only run electric, but I'm trying to get my RC8B3.1e to handle more like the nitro version. This will let me pick the correct battery/motor/weights to at least get closer. I know there's a lot of other factors, but right now my B3.1e feels like a dump truck when I have a full size battery in it and then is super sketchy when I use a shorty pack to get the weight closer to the nitro version. Pretty sure my weight bias is jacked up with the shorty pack, but now I can confirm.
#4118
Hey guys in case someone here in the forum don't use the social or don't follow us yet, we are pleased to inform all the AE users that today you have one more option to cover your RC8B3.1
We invite you to like our pages (FB, Instagram, YouTube) to stay update with our releases, next week also the VISION body for the brushless AE buggy will be announced, both nitro & electric are sold only Pre-Cut to give you the best with max. comfort!
Check out all the amazing features of this body at --> www.bittydesign.net/vision-rc8b31
#4120
#4121
The VISION bodies for Mugen and SWORKz we released in 2019 are sold pre-cut for both the Nitro & Brushless buggy, the next week we will release the AE VISION boduy for their e-buggy, the design has been engineered to have enough clearance for the lipo pack. MP10, Xray, Tekno, Agama and HB are the next!
#4122
#4124
Hello. I bought an RC8B3.1 and would like to know the measurements of the suspension gemmetry in degrees. Can anyone help?
#4125
Updated car has been released: https://www.associatedelectrics.com/.../RC8B3.2/Team/
Features
- New suspension arm design with inserts for flex adjustments
- Longer rear suspension arm length with narrow rear arm mounts
- New center bulkhead splits and has front/rear specific top halves to prevent brake misalignment
- Enclosed battery box for quick and easy battery removal
- Larger receiver box for better wire management
- One-piece graphite transponder and electronic switch mount
- Flex Control(r) radio tray has three different configurations for chassis flex adjustment
- New stiff shock bladder design improves jumping and handling performance
- Updated shock cap works for bladder or emulsion style shock setups
- Shorter and lower front bumper reduces drag and allows easier access to anti-roll bar screws
- I.F.M.A.R. approved rear wing
- 42T ring and 12T pinion gears on front and rear differentials for improved gear ratios
- Updated chassis with chamfered front edges to reduce drag
- Side guards are now threaded into the chassis from the top side of the car
- 90% parts compatibility with RC8B3.2e
