Mugen MBX7
#5086
how much do you guys preload the servo saver spring?
It feels like the manual setting is way to soft?
#5087
6 mm is my preload, europe tracks.
#5089
I just tried to set the preload at max (where the threads stops)
and still i can move the wheels quite easy when the power is on.
normal or not?
normal or not?
#5090
you need the silver spring, black is too soft
#5091
Ultimate rc
Im in New Zealand , got the Ultimate rc pistons 8x 1.2 from a trusted supplier
www.redsrc.co.nz
Im sure they'll send to US if you cant find a supplier.
www.redsrc.co.nz
#5098
Hi, Just interested to know if anyone has played around with adding weights to the front of the MBX7 to get the balance spot on at 50/50 front to rear?
As they come out they are pretty much rear heavy.
If anyone has done it, did it handle better that was or dose it handle better being rear heavy?
Cheers.
Cheers.
#5099
Cheers.
Cheers.
#5100
Cheers.
Cheers.
I have a buddy that added front and rear weights to his MBX6R and loves them.
