Mugen MBX7
#5073
If you move the shaft a few times up and down, they should get in place. I don't have any problems with them.
#5074
Here's a few pics of my MBX7Tix chassis. Ive been playing with this for a little while now. The chassis uses the x7 radio tray, guards, steering geometry, servo saver and ackerman, top plate and F/C driveshaft. The weight is further forward than the stock 6T setup generating a lot more steering than before.
#5075
#5077
Can someone confirm if the M2C throttle servo horn works without any mods on the 7? I am on the look out for a metal horn since the stock plastic is not inspiring any confidence. I used the Hudy on the 6 and it was great. The 7 brake linkage seems to be raised.
Why can't Mugen make a metal splined one? It's the splines that gets eaten away not the arm itself.
Also the screws that hold the sway bars on the diff case is elcheapo. The 6 has better 2mm screws.
#5079
It is possible, but there are chances that you damage the boot. It's best to slide over the shaft without the ballends installed.
#5080
#5083
could anyone tell me the length of the front cva from dog bone pin to axel pin. part # e0222? the one i need is 93.5 mm. thanks in advance
#5084
#5085
My mbx6 boots always teared at the ballend and they stayed pretty clean imo and these fit even better so I wouldn't worry too much.
