Mugen MBX6
Hi!
Guys. how to set up properly MBX6 on Hudy OFF ROAD Set up?
I can't set camber properly , because when i set up 3 degreese and i checking toe and when I mount tires ,tires are not in the same position.
Regards
Regards
When your car is bolted to a setup station the geometry is actually incorrect and gives a false reading.
The best way to set your camber is to use some blank rims and a camber gauge on a setup board. Set your ride height with the tires you want to run, pull them off and use some blank rims to set toe and chamber. You can measure from front of rim to rim and rear of rim to rim to get your toe. I run 0deg of toe, so my measurement from front of the rim to the rear of the rim is the same. I have always ran 0deg on 4wd cars.
But you are talking about toe not camber,is that right?
Regards
http://www.rpmrcproducts.com/product...hires/7099.htm
On 1 to 1 cars, they use a aluminum plate on both sides of the car and measure front and rear of the tire to get toe. The pic is just a fancy tool but you can get the idea. I just carry this idea into RC racing.
http://www.rpmrcproducts.com/products/tools/gauges.htm
Just saw they make a toe gauge as well. I have never used or seen one...
Hi.
How do you guys adjust your rebound in shocks? And how to set 100% rebound in mugen's shocks ? I can't do it in mugen but in kyosho or asso shocks it's very simple to me. I tried to rebuild my shocks in a few ways but no results. All the time rebound is close to 0%.
regards
regards
Scott
always run my shocks with little to no rebound tbh
Fresh Load Of Light Weight Goodies
Any chance some of those are going to the OSS race this weekend??
I just did the experiment myself and you are correct. It is indeed different when the wheels are on compared to what the setup station says it should be ? But why is what i would like to know.
My Huddy camber gauge is showing 3deg of camber and its correct, the gauge is in fact leaning in on a 3deg angle. But as soon as you attach a wheel (in my case a brand new AKA Evo with wheel stiffener installed) it is showing 0deg ? That's a big difference. And i put a carpenters square up against the wheel and it is in fact at 0 or 90deg with the ground.
Why would the setup station be designed is such a way to give false readings ( well its not really false but its different to what the wheels are when installed on the car) ?
