Mugen MBX6
Hi.
How do you guys adjust your rebound in shocks? And how to set 100% rebound in mugen's shocks ? I can't do it in mugen but in kyosho or asso shocks it's very simple to me. I tried to rebuild my shocks in a few ways but no results. All the time rebound is close to 0%.
regards
regards
Scott
always run my shocks with little to no rebound tbh
Fresh Load Of Light Weight Goodies
Any chance some of those are going to the OSS race this weekend??
I just did the experiment myself and you are correct. It is indeed different when the wheels are on compared to what the setup station says it should be ? But why is what i would like to know.
My Huddy camber gauge is showing 3deg of camber and its correct, the gauge is in fact leaning in on a 3deg angle. But as soon as you attach a wheel (in my case a brand new AKA Evo with wheel stiffener installed) it is showing 0deg ? That's a big difference. And i put a carpenters square up against the wheel and it is in fact at 0 or 90deg with the ground.
Why would the setup station be designed is such a way to give false readings ( well its not really false but its different to what the wheels are when installed on the car) ?
Finally...got my buggy today now I just need an rx batt, , and an engine I hope to do my first race this weekend
also what do you guys suggest for a cheap lipo rx pack for the mbx 6?
lmk
thanks
Jayson
lmk
thanks
Jayson
Because when wheels are mounted on our cars and on the ground they commit a outward pulling tension on the upper links, all the while pushing in on the lower arms.
The current crop of setup stations load the suspension in the complete opposite; push in on the upperlinks and pull on the lower arms. With the native sloppiness of an rc cars suspension this can mean a 1-3 degree different interpretation of a cars alignment.
When a car rounds a corner it is pulling on those upper links, never pushing in. So now you see why current setup stations have limited value. I gave up on my hudy station long ago after seeing this problem and developed one that addresses it. You hear that Joey? You and your multitude of vertical machining centers you.
Hi!
Is my mugen is set up correctly ? You can see on pictures, not precisly but always.
Front Toe : 1 degree
Front Camber : about 2 degree
Rear: i haven't changeed it since i have m spec mbx6.
Regards
Pictures : http://www.flickr.com/photos/6295748...7626740175402/
Regards
Hi!
Regards
Regards
Come by the shop tomorrow, we can talk then. 3:30 ok?
anyone know where to buy mbx6 european spec ?
