Mugen MBX6
#3452
Well its not really gravel on top it mixed in with the clay, which I think is weird as well. And the gravel is sharp small piece's and really shreds tires fast too. It is a new track here locally that the city helped build, so we really can't complain too much. We are in the process of trying to sift all the gravel out in the next few weeks.
#3453
I am runnin 773 and it is pretty dialed. I will try 753 when the traction is not that great, but so far 773 is pretty good. I just dont like running 5k in the front unless the track is very tight and I have to have sharp off power steering. I really like to stay in the throttle in the turns and I find 7k lets me do this, it also pulls better mid corner and exit. I cant really complain about the off power steering either as the car will carve sharp 180's no problem.
#3456
I'm at 5-7-3 right now, but I think I will like 5-7-5 and stay there. My car has MUCH more steering with the 5k front compared to when I had 7k in there. On super high bite tracks the front diff weight didn't change a thing, but once you got off in the little marbles 7k would push hard coming in or coasting through. I think it really depends on your track surface and conditions..
#3457
has anybody tried 5-7-2 and does anybody have a good set up revelation
raceway
thanks
raceway
thanks
#3458
7, 5, 4 has been the best for me and my driving style. That is one of the biggest factors with the diff setups. Driving style has more to do with the setup then anything. Just because joe blow likes 775 or john doe says 555 has been the best, you need to try the different setup out for yourself to see what you like best. That is what I have had to do and its taken a couple months of trying different things before I finally got it right.
#3459
to replace the front upper arm rear mount with the alum one, what screws do I need to remove, just the 2 in the mount?
#3460
The Mugen Al piece uses the same bolts with nuts underneath. Just take the screws out the stock part and then remove the top graphite plate. Swap the part out and reinstall. The M2C part has threading in it, so no nuts are used underneath to hold it in place. I used bolts that were 2mm longer I believe with the M2C part, but I have to check to make sure.
#3461
JR servos?
sorry to change the subject but i just purchased jr servos 9100t and 9100s
but i am having trouble putting them in the radio tray its really tight without
the plastic bars. can i put them on the tray without the plastic parts or should i file the tray.
thanks
thanks
#3462
what platice parts are you talking about? the part that gose on the servo form jr?
#3464
no the little plastic part that looks like a block but has a little lip and it comes in different thickness for differnt servos comes with the kit
thanks
thanks
