Like Tree3Likes
Mugen MBX6
Old 05-07-2009, 02:36 PM
  #3466
Sprinkler's Avatar
Trader Rating: 28 (100%+)
7, 5, 4 has been the best for me and my driving style. That is one of the biggest factors with the diff setups. Driving style has more to do with the setup then anything. Just because joe blow likes 775 or john doe says 555 has been the best, you need to try the different setup out for yourself to see what you like best. That is what I have had to do and its taken a couple months of trying different things before I finally got it right.
Sprinkler is offline
Old 05-07-2009, 04:02 PM
  #3467
R/C Tech Elite Member
JayL's Avatar
to replace the front upper arm rear mount with the alum one, what screws do I need to remove, just the 2 in the mount?
JayL is offline
Old 05-07-2009, 06:20 PM
  #3468
ezveedub's Avatar
Trader Rating: 17 (100%+)
The Mugen Al piece uses the same bolts with nuts underneath. Just take the screws out the stock part and then remove the top graphite plate. Swap the part out and reinstall. The M2C part has threading in it, so no nuts are used underneath to hold it in place. I used bolts that were 2mm longer I believe with the M2C part, but I have to check to make sure.
ezveedub is offline
Old 05-07-2009, 07:57 PM
  #3469
Default JR servos?
sorry to change the subject but i just purchased jr servos 9100t and 9100s
but i am having trouble putting them in the radio tray its really tight without
the plastic bars. can i put them on the tray without the plastic parts or should i file the tray.
thanks
JHN1 is offline
Old 05-07-2009, 08:01 PM
  #3470
porkchop's Avatar
thanks
what platice parts are you talking about? the part that gose on the servo form jr?
porkchop is offline
Old 05-07-2009, 08:08 PM
  #3471
slidejob26's Avatar
thanks
I am running the same servos and I did not file anything, they fit fine.
slidejob26 is offline
Old 05-07-2009, 08:09 PM
  #3472
no the little plastic part that looks like a block but has a little lip and it comes in different thickness for differnt servos comes with the kit
thanks
JHN1 is offline
Old 05-07-2009, 08:12 PM
  #3473
BSchorr's Avatar
Trader Rating: 101 (100%+)
Those pieces are to lift the different sized servos off the chassis, and also to make the linkages level from the center diff area and from the servo saver. So there is less binding when the servo's are working/chassis flexing.
BSchorr is offline
Old 05-07-2009, 08:19 PM
  #3474
T-spoon's Avatar
Unhappy
I had a little trouble getting mine in also.I just kept messing with it and i finally got it to go....
T-spoon is offline
Old 05-07-2009, 08:20 PM
  #3475
BSchorr's Avatar
JR servos do run big, it sucks.
BSchorr is offline
Old 05-07-2009, 08:27 PM
  #3476
T-spoon's Avatar
Cool
Yea, it was jr servos that gave me a little trouble...
T-spoon is offline
Old 05-07-2009, 08:33 PM
  #3477
so should i file the little lip thinner
thanks for all the help
john
JHN1 is offline
Old 05-07-2009, 08:35 PM
  #3478
T-spoon's Avatar
Red face
I didn't have to.It took me a little while but i managed to get it...
T-spoon is offline
Old 05-07-2009, 08:57 PM
  #3479
ezveedub's Avatar
The JR servos are larger than others and can be a pain in some cars. On the steering servo, I took a flat file to the sides only, so it wasn't so tight. Only a few strokes with the file though, so it slides in snug, not having to be forced in. On the small securing blocks, I used one with the lip in like the manual states, to take up the space and the other one flipped so the lip is down.
ezveedub is offline
Old 05-08-2009, 12:16 PM
  #3480
do you guys think its a good idea to buy a second kit and use it for parts
JHN1 is offline
