Like Tree3Likes
Mugen MBX6
Old 05-08-2009, 04:31 PM
  #3481
Default JR servos?
I just purchased the jr9100 steering and throttle servo and went to check if everything is working okay the steering works great but the throttle servo does not move i tried to turn it by hand and it doesnt turn so i know theres some juice going into the servo but its not moving?
any help please
john
thanks
JHN1 is offline
Old 05-08-2009, 04:35 PM
  #3482
porkchop's Avatar
any help please
john
thanks
radio end points?
porkchop is offline
Old 05-08-2009, 04:40 PM
  #3483
FrankBlack's Avatar
Originally Posted by dead1dave
So I have heard so many favorite "diff" setups so far I'm really confused ..................what the best "diff" setup if the traction is low ? I got my car just before CRCRC and have only run it indoor ..running 7/7/5 .......went outdoor last week and I was like a fish out of water ...LOL .......the right tires made a night and day difference but I just wonder if I don't need a different outdoor setup . Thanks guys !
7/7/5 wont work in low grip conditions, i switch to 5/7/2 if the grip is low, you loose onpower steering though, 5/5/2 would work aswell.
FrankBlack is offline
Old 05-08-2009, 04:44 PM
  #3484
evrything is in nuetral
JHN1 is offline
Old 05-08-2009, 04:45 PM
  #3485
R/C Tech Elite Member
BSchorr's Avatar
Trader Rating: 101 (100%+)
any help please
john
thanks
Sound like you got a dud servo.
BSchorr is offline
Old 05-08-2009, 05:07 PM
  #3486
Dal
Dal's Avatar
Australia best driver, Wayne Walker, 2 times current Aus champ, MBX6, has used 5/5/5 for the last 3 big meets hes been in, he loves it, and yes 3 different tracks, but then again, he is a super freak driver, down here.
He also has lifted the Ackerman bar by 4 or 5mm to get rid of the bump steer, which WAS , but not now, giving the outside front wheel understeer as the car leans through the corner.
I now have copied it, and on the bench looks great.
Is that you reading my post Dawson????? huh huh
Dal is offline
Old 05-08-2009, 05:09 PM
  #3487
can it be from a dead battery
JHN1 is offline
Old 05-08-2009, 05:38 PM
  #3488
Trader Rating: 16 (100%+)
What type of radio do you use? I have seen issues like this on dx3r where a toggle switch by your thumb can accidentally kill the throttle servo movement.
Adim_X is offline
Old 05-08-2009, 07:05 PM
  #3489
yes its the dx3r but i never had any trouble before
thanks
john
JHN1 is offline
Old 05-08-2009, 07:51 PM
  #3490
I would start with the E rocker switch and see if some movement comes back. You can also create a new profile and see if that fixes it. Those rocker switches are easily hit and can mess up settings. I have a buddy who just sent his radio into horizon for this issue and it turned out, a setting was jacked up from those rocker switches.
Adim_X is offline
Old 05-09-2009, 06:19 AM
  #3491
The problem is that the steering servo works fine just the throttle servo is not working. How can i fix the toggle switch
thanks
john
JHN1 is offline
Old 05-09-2009, 08:18 AM
  #3492
Alffa164's Avatar
thanks
john
Dude.. before going any further change the servos in the RX output. Put the throtle servo in the steering channel and vice versa. Since your steering servo is working fine this will tell you if its the throtle servo itself or just a bad setting on your radio or your receivers throtle channel is bad.
This is as simple as switching two cables.
Alffa164 is offline
Old 05-09-2009, 10:32 AM
  #3493
smracer31's Avatar
Charge your battery and do as suggested, rebind your controller to the receiver on a new profile on the controller. Also make sure your servo is plugged in the right way on the receiver.
Your local track is revelation correct? the guys at air land are very helpful if you need assistance! Well be there testing an mb6x tomorrow as well
smracer31 is offline
Old 05-09-2009, 11:36 AM
  #3494
thanks for all the help guys
just wanted to let you know i just received bill chassis (bce) have not had a chance to run it yet but will post some pics later this week but so far it looks great.
john
JHN1 is offline
Old 05-09-2009, 08:36 PM
  #3495
tunerjetta29's Avatar
Picked up a jammin jp3 pipe. Both the jp3 and dynamite pipes are an extremely tight fit. What pipes are you all running that give you decent body clearance and are durable?
tunerjetta29 is offline
