Team Associated 1/8 scale Buggy Info and Tips
#3886
Guest
clutch
That was kinda my thought that perhaps some grease or something had gotten onto them. The bearings were on there from the previous set of shoes, which I had no problems with. I did notice that there was a little bit of oil it appeared around the bell/flywheel when I pulled it apart this evening.
#3887
Guest
hey guys do u all ever take ur clutch bells and sand the inside out, just to give the new clutchs a new surface to grab on to? and the bearings i clean out the grease from the fractory and soak them automatic transmission fluid over night. i will use a set of bearsing in month of racing.
#3888
ive been running the same shoes with no maintnence for 3 race weekends shoes still look great i recently added 2 setscrews to the impulse rc shoes it softend up the bottom end alot but i think it was too much sop im going to remove one of them before the next race and see how it works
#3889
Location: If i'm not in England i'm in Southern California
#3890
Clutch Bearings
TKO clutch bearings w/ TKO conical washers works great for me. The washers only touch the inner race. I believe this reduces heat and friction on bearings.
I had a center front CVD pin fly out this weekend. I'm running the AL CVD cups and the ring that captures the pin spun on the cup to just the right spot. I put a 3/4" piece heat shrink tubing on it to prevent this from happening again. Looks like it will help keep them cleaner too. While I was at it, I tried a rear CVD boot on the center rear CVD and it works great. This should keep them clean and increase longevity.
#3891
Somehow things are confused on my car...
Are the front and rear outer driveshaft assemblies the same length????
If not i have rears on the front, if so i have a troubling issue of play that is allowing the outer bearing to move in and out of it's place in the steering knuckle.
#3892
Proof--> http://www.amainhobbies.com/product_...ducts_id/17410
#3893
Yup, spot on. I made a nice schoolboy error!
#3895
yup...got a crack above the nipple on my white tank. Came pre-installed when i bought i from Carolinasrc about a month ago.
Pretty amazed about how this thing handles compared to my 777sp2 btw. Never had a 1:8 car that turns like this one. Looking forward to my next race
#3897
i have a crack on the white tank.leaks like crazy?
#3900
With all the tank problems, is there another brand that fits?
