Team Associated 1/8 scale Buggy Info and Tips
#3916
Ae BIG Bore Shocks
Got to check out the new Ae big bore shocks today for the RC 8.
very nice
Improved seal cartridge for the O-rings, it thread`s onto the bottom of body . No C-clip...
Nice metal caps
expose bleed or vent hole in cap
nice bladders on top
pistons had a lot more holes , I think 6 and they were 1.3
No pic will get some tomorrow...
very nice
Nice metal caps
#3922
What all do you have to do to make the Jammin 16 mm bb's fit? I just bought a set and wanted to know how they fit on the buggy. Thanks!
#3923
I would wait for the AE ones though, I ran them at the Pre worlds a couple weeks back. Built them on Thursday and on Sunday they were still perfect after putting 1.5 gallons of fuel. Easy to build, few new parts, but uses same o rings and spacers and shafts, so a good bit of your spare parts will still be useful. Same length, so internal limiting on set ups works the same, etc.
#3925
Hey brandon,
Do you have an eta on when the new big bores might come out? I will get them either way, but just curious ..thanks!
#3926
heard from a guy at AE that big bores were about a month away!
#3927
you will need the original shock standoffs for the 13mm shocks from a jammin x1. they are a bit shorter than the standoffs that come with the sbb shocks. you will use the balls from the ae shock ends and will need to dremel a bit off of the side opposite the locknut on the shock mounts (just enough that the shock ends from the jammin shocks move freely, so check them as you go).
#3929
ofna super big bores with 13mm standoffs. I used one thin washer behind each standoff to space out the shocks just right.
#3930
Location: If i'm not in England i'm in Southern California
Kyosho shocks?
Bear in mind they are short. If you use them you will need to widen the shock tower...
Does anyone know which Jconcept tyres the pros where using at the Thunder Alley Roar Nats?
