Team Associated 1/8 scale Buggy Info and Tips
#3901
My new white tank cracked where the springs for the gas cap sit on the tank. I think AE will take care of us but the tanks are currently on backorder and doesnt sound like they will be available for a couple of weeks. I talked to Don from AE on the issue earlier this week. If this keeps up im just gonna mod another brand of tank to fit , i get to race once a week and sometimes travel over 2 hrs to race. It kinda stinks to spend way over a thousand bucks to set up a competitve buggy and i try to all of the best stuff avaiable and a stupid $20 dollar gas tank ruins the whole raceday.
Anyone else tried a different brand tank yet?? I think the losi tank with the "clunker" would be awesome.
#3902
#3904
I know some guys here use the 808 tank without too much mods.
#3905
Guest
gas tanks
i thought about spiting the tank apart, and cutting out the stiffeners out, and drill a hole in the tank and make it like the losi gas tank. but i dont know what to use to seal up the tank again. or does this sound like a dum idea??
#3906
Tank problems
Would anyone be interested in an custom aluminum tank at about $50-75 a piece? Looks like there is a market for quality tanks. Just read an article about how NovaRossi is selling exhaust gas coolers to increase fuel mileage. An aluminum tank would keep the fuel cool and be tough as nails. Keeping the weight and cost down would be the only challenges. I could have the first one wiped up in Solid Works and have it laser cut and welded in about a week.
Also, I'm testing some custom Titanium toe plates for the RC 8. I got other little bits and goodies in the works that I'll reveal later.
#3907
Location: San Marcos/San Antonio, Tx but chillin in Orlando, FL for now.
Can anyone using a OFNA chrome top starter box please post a pic of their set up. Its a bit tricky getting the posts set up so that the car seats properly and I am hoping some one can shed some light on the subject.
-M
-M
#3909
AE is aware of the new take troubles and have pulled all the cracked ones from there stock.
If you have a tank that has the little crack above the fuel nipple you can fix it really easy. Take nipple out and put a small amount sealant on the threds. Put the nipple back in and then use a soldering iron to seal the crack and all is good.
#3911
is it unheard of to run 30 or 35 weight oil in the back with 1.6 pistons.i run on a real rough track and 50frt and 40 rear is way to heavy,thinking of 40frt and 35 rear?any comments
#3912
I ran that in the winter when it was real cold. Now outdoor also on real bumpy blown out tracks I'm at 40 with the 1.4 pistons with the 2 additional 1.1mm holes drilled in them. That's front and back.
There's nothing wrong with what you are suggesting. Give it a try. We're not all Tebos and Cavs, so sometimes ya just have to work your own setup.
#3913
This buggy does have spiral cut gears right? Like on a truggy? Just curious!
#3914
got my updated tank today and didnt find any crack around the nipple. Goodstuff
#3915
dup
