Losi 8ight building and setup
#6016
Domit - Thanks for the word.
ezveedub - When you mount your batteries in the Losi, cut a peice of lexan the same square size as the batt box. Sticky tape your battery to the Lexan and install.
This spreads the load evenly on the bottom of the pack and does not let that screw area comprimise your cells. It also keeps your pack from shifting around in the box which can eventually mess with and strain your wiring.
I used those spacers on my rear center shafts as well. I took one look and knew that would be the way to go.
When the car was tight it would wander all over the place on the straights so I found myself constantly correcting it. With it stock if I hit a good line comming on the straight I can actually scratch my nose and take a break until the end. Much easier to deal with during long mains.
Good thread guys.
TEX
<------ Not done yet!
Good thread guys.
TEX
#6018
Here is what I did. If you want to know the details, LMK, as there is a .3mm Kyosho shim placed in between the washer and the bearing to prevent any issues with the washer rubbing the bearing races and damaging it.
As you can see, the CVD is now "plunged" further into the outdrive cup.
#6021
on that center drive line mod did you do it to the front.what kyosho shims did you use.Iwas checking the outdrives cups on the f/r diff they had a lot of slop got new outdrives cups and the new cups came with shims installed with out shims same slop installed shims and had a lot less slop the shims are
.2mm could use a .3mm or .4mm thinking about trying the mugrn diff shims
.5 mm is to much
.5 mm is to much
#6022
.5 mm is to much
.5 mm is to much
#6023
Those Kyosho shims are ur best freind when it come to shimming.....those and OFna 5x8's are A MUST in every racer's tool box....i CANT COUNT how many guys buy the bulk ofna shim kits to only get like 2 or 3 5X7 shims and the rest is practically useless.....THank you kyosho and ofna for making these shims. they make shimming a clutch a Dream.
#6024
Can soeone post the CC on the tank cappacity without the piece of plastic mounted in it.
Specialy fore the 8B but 8T whould be nice too.
I have a race next weekend the 20th and I want to know if I can remove it without beeing illegal.
thanks Hellsavage
thanks Hellsavage
#6025
on the mod to the rear drive line the washer is a std washer or what does it normanely fit
#6026
#6027
I saw the .3mm shim in the pic it looks like there is a thicker washer in the pic
besides the .3mm
besides the .3mm
#6028
#6030
No the shims are for spacing the washer off the bearing. It contacts the inner race of bearing only, so you don't ride the washer across the inner and outer races. This will add friction and heat the bearing up, making it fail prematurely, just like the clutch bearings will do with full size 5x10 shims. I had a thick washer in my pit box, but basically any washer with a 5mm inner diameter and say about 2-3mm thick will do. This mod is more important when running the plastic rear brace, which a lot like to do. I actually sent a email to Losi about this center rear axle being too short. My Kyosho and Mugen are plunged way into the drivecups compared to the 8ight.
You could stack up some .3mm shims up instead if you couldn't find a washer IMO.
