Losi 8ight building and setup >
Old 12-31-2007, 06:02 PM
  #5866
Integra's Avatar
Originally Posted by Mcfly
hi guys, trying to go better this year with the losi 8 and have heard some people overdrive the front, has anyone here tryed it, and if its worth trying what do i need for it?
Overdrive the front ? huh
Integra is offline
Old 12-31-2007, 06:17 PM
  #5867
BOOST's Avatar
Yea what?? How about explaining that a bit more with some detail!
BOOST is offline
Old 12-31-2007, 06:26 PM
  #5868
SCUBA STEVE's Avatar
Trader Rating: 89 (99%+)
That's more for on road, never heard of it done in 1/8 buggy........
SCUBA STEVE is offline
Old 12-31-2007, 06:29 PM
  #5869
Mcfly's Avatar
from what i gather its like onroad racing where the front wheels are geared taller than the rear and therefore have more drive, the way i guess you would do it with the losi 8 would be to use rear diff gears out of the 8t in the rear of the 8. but the onroad dont have a center diff so with the 8 dont know how much difference it would make.
Mcfly is offline
Old 12-31-2007, 06:43 PM
  #5870
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
As Scuba Steve has pointed out, that is used in onroad, not offroad. Its also used to somewhat compensate for the tire wear and how the rollout changes for front and rear.
rezenclowd3 is offline
Old 12-31-2007, 06:52 PM
  #5871
Mcfly's Avatar
thanks guys, that answers my question of do people use overdrive.
Mcfly is offline
Old 12-31-2007, 07:25 PM
  #5872
rockfordccinc's Avatar
Questions??
i'm sure the info i'm looking for is located somewhere in this million post but what are some servo combos being used in the eights. I have a jr 9000s that has only been run once, so could this be useful. I doesn't matter i just want what is needed.
Thanks David
rockfordccinc is offline
Old 12-31-2007, 07:36 PM
  #5873
air8's Avatar
Thanks David
Hey Rock, the JR's will work great. I use the ACE servos. And if each person on this thread were to answer you would have each and every manufacturer used. So just use good servos and you won't have a problem. Set the EPA's correctly and make sure the carb slide is moving straight in and out. Set up your brakes so that the servos aren't maxed out while you're on the brakes and you won't have problems.
air8 is offline
Old 12-31-2007, 10:45 PM
  #5874
Thanks David
The 9000S you have will be great for steering, but for most it's too fast. If your radio TX supports it, it may be useful to slow down the servo speed.
Old 12-31-2007, 11:19 PM
  #5875
joecool's Avatar
Trader Rating: 22 (100%+)
i can ship this kit to someone for $400. PM me if your interested.
Originally Posted by cfish8u2
Joe Cool,
Eddie is right sorry man, you must have over paid when you got it.
If you want to go 375 shipped let me know.
joecool is offline
Old 12-31-2007, 11:27 PM
  #5876
The For Sale/ Trade section is a better place for this.
Old 12-31-2007, 11:31 PM
  #5877
BOOST's Avatar
I use the 9000 for steering and I don't water it down, I like the speed it has on tap but for most it is probably a tad too fast.
BOOST is offline
Old 12-31-2007, 11:51 PM
  #5878
Best way to see is IF you are already a consistent driver, to test your lap times back to back with full servo speed and a slightly slower servo speed.
Old 01-01-2008, 08:25 AM
  #5879
thanks everybody but if i were to use the 9000s what would be a good choice in the jr family of servos for the throttle.
Old 01-01-2008, 08:39 AM
  #5880
dam
How loose do you set your servo saver?
dam is offline
