Offical ARRMA KRATON MT thread
#286
Thanks man, I'll try that first. I'm also still looking for a good shock oil weight. I think the stock weight is 45. Also diff weights. I think the stock weights are 7-10-7. Would changing the diff oil help keep my front end down.
#287
Finally made up a set of super swampers with studs for the snow
Used the AKA tire punch for the holes , On the studs used blue loctite to hold em in . Studs 3/8" high . Put 24 on each tire , Just need to balance em out and let em setup overnight
The Super Redcat wing still holding up fine .
#289
I've been watching the kraton and the tailon pretty closely and it looks like they have updated the bad areas like the esc. I'm going to wait a couple months so I make sure to get an updated one and pick one up.
#290
Thicker center diff fluid might help. Thicker center diff fluid will reduce balloning, but it will also allow more torque to reach the rear wheels which will tend to lift the front end. Reducing the balloning by tieing or duct tape the tires should help for sure.
#291
Is the stock Kraton servo digital or analog? Anyone know for sure?
#292
#293
I just ordered a Futaba 4PLS. I was told that I have to use a digital servo because an anolog one would burn out. Is that true? And has anyone swapped servos in the Kraton that can recommend a decent one. I don't want to spend a whole lot either (under $80)
#294
Im using the Savox SW-0231
Under $50 works great in the Kraton with AVC and its waterproof
#295
I was just going to swap out the receiver and radio. I have a Tactic radio I like, so I was going to drop that in. I'm not sure about the whole digital/analog thing. Is that going to be a problem for the servo and esc?
#296
Digital servo only matters if your using Spektrum and AVC receiver
#297
Do you know that for sure? Are you saying that using te analog servo with my futaba tx and Rx will be fine? The guy I talked to at hobbico support for futaba said an analog servo would burn out. It would be nice if I didn't have to swap the servo out right away. But I don't want I damage anything.
#298
#299
You have to adjust the frame rate on a futuba receiver to work with an analog servo .
All about servos
http://www.rchelicopterfun.com/rc-servos.html
All about servos
#300
All about servos
All about servos
