Offical ARRMA KRATON MT thread
#301
That was a good article. I have no idea how to adjust te frame rate or really what that means (I didn't catch anything about that in the article) but I think just upgrading to digital is a better choice anyways. With thT said I have a mm2 and I can adjust the voltage up to 7.4 for the tv servos but should I be using a bec for that? Or even for 6volts? Not 100% on what they do either but it seems like thy woul put out the voltage instead of the voltage coming off the esc internal bec? If the voltage is coming out of the esc bec what else is being robbed of that power? What I mean. Is something else getting less voltage because I am sending 7.4 to the servo and throttle?
#302
The voltage specs a manufacturer lists is usually the max it is rated at @ that voltage. The ESC will have a internal bec, on that mm2 its default is 5v I believe. You can adjust it up to whatever, if the servo is 6v then adjust to 6v. The bec supplies power to the servo and Rx. Adding an external bec helps when you put a voltage hungry servo on board, but my guess you can upgrade that servo on the kraton without going crazy and not adding an external bec. Bec is battery eliminator circuit I believe too. So you just put to a limit on the max vo!tags to servo and Rx, typically under a load that voltage will drop, so to compensate for that I adjust a 6v servo to 6.4 or 6.6 can't remember but too much than you could blow it
#303
Ok thanks. So if I buy a 7.4 volt servo instead of an 6volt I can just bump up the internal bec to 7.4 ad probably still not need an external bec? Or would 7.4 be considered a power hungry servo? The mm2 is 5.5 stock but I have it at 6 right now cause that is all my current rx is rated for but the futaba Rx I'm waiting on is 7.4 ad so is the servo I'm looking at.
I have added one to ensure that everything works right with no issues. I also feel in my mind that it takes less stress from the ESC.
#304
Alright great, so if the Rx and servo are rated @ 7.4v than I would def run the bec that high. That higher voltage will give you more out of your servo. You may not need an external bec but a "hungry" servo for example could be a high voltage high torque spec servo. You would need to add one if you experience black outs when under a load. I would try the servo with the internal bec set @ 7.4 and then try it. If when your hard on the throttle and steering but its hesitating then I would recommend an external bec.
#305
No problem bud, but remember that servo that is rated @ 6v you can't raise it any higher then that even if the Rx can handle it. However if it was me, I would adjust it just a hair higher like 6.4v to achieve a steady 6v across the board, so when its under a load then you shouldn't drop below the 6v. I think I told you I run mine on the maxx at 6.6v but 6.4v should still be safe.
#307
The battery tray is 2 inches X 6 1/8. The two 2S side by side are " fairly secure ", but if you run 6S ( 2 X 3S ), you have to stack them. Those will move around on you. I actually purchased a second battery tray and sandwich them in. Then I put another velcro strap long ways across that. That holds them in there!
#308
1/8 plastic center diff
Anyone tried putting in a standard 1/8th buggy/truggy center diff in or perhaps just the spur. Running the metal stock is nice but looking for something more common.
#309
On a different note, I should have a new video up soon. I planned today but had some rendering problems before work. After 3 days of mudding, jumps (a 5S pack of 40+ ft ones), and just general bashing, I blew out a steering knuckle bearing. I'll be doing a teardown of the truck to redo the front/rear diffs, new tires, new rubber shielded bearings, etc. Time to bring it back this spring .
#310
Here's the new vid. I fired it up right from the basement and straight into the swamp lol.
+ YouTube Video | |
#311
+ YouTube Video | |
#312
Lol, that's one reason I didn't want to jump in that anymore. I only got a bit on the front a-arm but I sprayed the whole thing down with the hose afterwards. That's why I said I need a new place to jump
#313
I got my steering knuckles from "Omnimodels" on Ebay and they are the upgraded version. Unfortunately my bearings didn't come in at the same time.
#314
I was just thinking about buying a set of MBX7T shocks to put on the Kraton. From what I have gathered the Kraton shocks are approx. 118mm lg (front) and 137mm lg (rear). The MBX7T shocks are approx. 108mm (front) and 130mm (rear). So that is 10mm (.38") short in front and 7mm (.28") short in the rear. Right now the shocks are setup in the middle holes of the towers. I could move them to the closest setting giving me maybe .0625" of that length back. Do you guys think that those shocks are too short to use?
#315
