Mini-96 World Challenge
#1683
Class- Box Stock
Date- 4/3/23
Location- Singapore
Race Time- 367.630 s
Fastest Lap- 4.390 s
Chassis- MR-03
Body- Jomurema
Wheelbase- 98mm
Tires- Front PN KSM S, Rear Marka V1R05
Motor- Box stock
Batteries- PN750
Front Springs- PN Green
T-Plate- PN Fiber 4
Motor Mount- MM stock plastic
Dampener (If applicable)- Stock spring
Dampener Fluid (If applicable)- n.a.
Gearing- 7T pinion
Notes- Just swapped Mclaren 12C body to Jomurema. Felt so much heavier during turns; still getting used to it.
Date- 4/3/23
Location- Singapore
Chassis- MR-03
Body- Jomurema
Wheelbase- 98mm
Motor- Box stock
Batteries- PN750
T-Plate- PN Fiber 4
Gearing- 7T pinion
#1684
Class- Porsche Cup
Date- 4/3/23
Location- Singapore
Race Time- 370.942 s
Fastest Lap- 4.237 s
Chassis- MR-03
Body- Porsche 996 GT3
Wheelbase- 90mm
Tires- Front Marka V1R05, Rear PN KSM S
Motor- PN 70T
Batteries- PN750
Front Springs- PN Red
T-Plate- Kyosho RM Carbon Fiber Soft
Motor Mount- Atomic Rear Mount (not sure?)
Dampener (If applicable)- PN Dual Spring Center Shock (red springs front & back), PN Disc Damper
Dampener Fluid (If applicable)- Dry
Gearing- PN Ball Diff 53T, 9T Pinion
Notes- Swapped stock plastic rear motor mount with this aluminium one & PN 70T motor. There is zero traction roll but I'm now slower than stock configuration. So strange...
Date- 4/3/23
Location- Singapore
Chassis- MR-03
Wheelbase- 90mm
Motor- PN 70T
Batteries- PN750
#1685
Class- Formula 1
Date- 4/3/23
Location- Singapore
Race Time- 352.469 s
Fastest Lap- 4.099 s
Chassis- GLF-1
Body- GLF-1 Lexan
Wheelbase- 114mm
Tires- Front 11mm PN Low-profile KS-M Soft, Rear 14mm KS-M Super Soft
Motor- PN 3500KV
Batteries- Atomic 350mAh LiPo
Front Springs- Stock
T-Plate- N.A.
Motor Mount- GLF-1 Stock
Dampener (If applicable)- GLF-1 Stock
Gearing- GL Racing Ball Diff 53T, 10T Pinion
Notes- Had to turn down throttle to 50% for the Mini 96 track. So hard to steer cleanly around the 180 deg turns. Are there other GLF-1 owners in the M96WC challenge?
Date- 4/3/23
Location- Singapore
Chassis- GLF-1
Body- GLF-1 Lexan
Wheelbase- 114mm
Motor- PN 3500KV
T-Plate- N.A.
#1686
Class- Open 2WD
Date- 4/3/23
Location- Singapore
Race Time- 337.491 s
Fastest Lap- 3.955 s
Chassis- GLR-GT
Body- Jomurema
Wheelbase- 98mm
Tires- Front PN KS-M Super Soft, Rear Marka Radial 5deg MRZ-V1RR05
Motor- Rocket Brushless 3500KV
Batteries- GL Racing 350mAh LiPo
Front Springs- Purple
T-Plate- N.A.
Motor Mount- GLR-GT Stock
Dampener (If applicable)- Reflex Racing RX502
Gearing- PN Racing Ball Diff 53T, 10T Pinion
Notes- My first run with the GLR-GT.
Date- 4/3/23
Location- Singapore
Chassis- GLR-GT
Body- Jomurema
Wheelbase- 98mm
T-Plate- N.A.
#1687
How old is your track? Takes a few months of use before some of the tracks make really good traction. Running on a new unbroken in track is easy 0.5 seconds slower per lap. If you track is broken in try different lines for the corners. I slow way down and hug the line really tight at the apex for most turns. I can try to get some video next time I set up my track.
#1688
Well I am getting my White bodies ready for paint and got the clip height set, and got the wheels as wide as will fit cleanly under the bodies. I'm still thinking on colors and practicing with my airbrush. Really thinking of the green and yellow City Chevy from "Days of Thunder" for the Skyline to a tribute to one of my Best Childhood friends who suddenly passed last week, and Days of Thunder was one of our favorite movies! Smokey and the Bandit was our other go to movie, but the black is too hard to see on the dark track. Rest in Peace Jeff!!!
I'm running a McLaren 12C for box stock, and the Skyline R33 in stock. The McLaren is running well as I have it setup, although it seems slow compared to the Skyline with the PN 70t. The Skyline is running narrow wheels all the way around, as I couldn't fit wide wheels, even -1W without SERIOUS grinding the body, and I have to be careful on the throttle as I can spin it out at will. I am going to try some softer tires to see if it helps. Anyway here's my beginning times for the month. My fastest laps are going down as well as my total times are improving, but mistakes mainly caused by nerve damage in my right arm still plague me. Still having a BLAST both driving and wrenching trying to improve my times, and Thankful for the Help Yall provide!!!
Class- Stock
Date-03/09/2023
Location- Central Texas
Race Time- 05:42.915 / 342.915 seconds
Fastest Lap- 3.778 seconds
Chassis- MR-03
Body- Nissan Slyline R33
Wheelbase- 94mm
Tires- F- N 1mm Kyosho low height medium / R- N 0mm PN KS RCP Medium
Motor- PN70
Batteries- Eneloop 800hv
Front Springs- red
T-Plate- #4 Carbon
Motor Mount- PN V3 94-98MM
Dampener (If applicable)- PN MR2061 Graphite Disk Damper- both disks with green springs
Gearing- 64pitch 9t pinion/53t spur PN Gear diff
Notes- Fast but backend washes out under power very easily.
Class- BoxStock
Date-03/09/2023
Race Time- 05:44.931 / 344.931 seconds
Fastest Lap- 3.791 seconds
Chassis- MR-03
Body- McLaren 12C
Wheelbase- 98mm
Tires- F- N 1.5mm Kyosho Low height medium / R- W 2mm PN radial soft
Motor- Stock white end
Batteries- Kyosho SpeedHouse 800hv
Front Springs- red
T-Plate- #4 Black Fiber
Motor Mount- Stock MM
Dampener (If applicable)- Stock Spring
Dampener Fluid (If applicable)- 15k Diff grease
Gearing- 7t pinion/ stock gear diff
Notes- BoxStock- nothing done to the front except for spring swap, in the rear I installed a aluminum t-plate mount, black fiber PN #4 t-plate, and PN 7t pinion. VERY STABLE and although it feels slow, the times don't lie!
Also I'm curious to see what happens to the times and handling with the added weight of the paint and body accessories after I finish the white bodies!
Take Care and Drive Fast!
Drew
Class- Stock
Date-03/09/2023
Chassis- MR-03
Wheelbase- 94mm
Motor- PN70
Front Springs- red
T-Plate- #4 Carbon
Class- BoxStock
Date-03/09/2023
Chassis- MR-03
Body- McLaren 12C
Wheelbase- 98mm
Front Springs- red
Drew
#1689
Sorry about your friend!
I’d swap the bodies and see how they do. The 12C is probably heavier and could benefit from the extra torque of the PN70T, while the Skyline with narrow rear wheels might be better with the stock motor. They might both be faster that way.
#1692
#1694
For example, two classes a lot of people confuse are "Spec Slash", and "Stock Spec Slash". Both are 'spec' classes...but, one (Stock Spec Slash) has more stringent specifications. The point is, whatever is stared by a class' "specifications", they MUST be followed. Now, anytime not covered by the 'specs' CAN be changed/adjusted/modified/upgraded.
Hope this helps.
#1695
Thanks Traveler! Jeff got me started in real rc when we were around 10. HE had a BlackFoot, and a SledgeHammer, and I had a GrassHopper, and we would bash the hell out of them! There were no SkateParks back then so we used to jump the SledgeHammer off his roof!
Lots of GREAT Memories!!
I was thinking about swapping the bodies, but before I do all that work I'm going to do some tests with tires, ride height, etc. to get the Skyline to stick. I have a feeling it has some great times in it. I have all the parts to setup the 98mm chassis to the exact stock setup as the Skyline, but I'm holding off to see what I can do with the BoxStock setup after all the laps I have turned since starting.
Also Can anybody tell me how I can get the Z Round lap tracker software to announce just the lap count? I am really loving how well the EZLap works, as it hasn't missed a single lap! It's the ZRound software that is difficult to figure out!
Thanks and Drive Fast!
Drew
Lots of GREAT Memories!!I was thinking about swapping the bodies, but before I do all that work I'm going to do some tests with tires, ride height, etc. to get the Skyline to stick. I have a feeling it has some great times in it. I have all the parts to setup the 98mm chassis to the exact stock setup as the Skyline, but I'm holding off to see what I can do with the BoxStock setup after all the laps I have turned since starting.
Drew
3035Likes
