Mini-96 World Challenge
#931
Class-Stock PNR 3500kv
Date-6/30/2020
Location-Winston-Salem, NC
Race Time-4:51.279 (291.279)
Fastest Lap-3.539
Chassis-PNR2.5W
Body-Ferrari 458 Italia
Wheelbase-98mm
Tires-K30 slick fronts, K20 radial rears
Motor-Rocket 3500vk
Batteries-Kyosho 800
Front Springs-PN Green
T-Plate-PN Carbon #6
Motor Mount-PN 98mm v5
Gearing-PN 64p 13/53 Ball diff
Notes-Car is very stable and quick, but with the brushless motor cars, I have difficulty recovering from a mistake and it costs me a lot of time.
Date-6/30/2020
Fastest Lap-3.539
Chassis-PNR2.5W
Wheelbase-98mm
Motor-Rocket 3500vk
#932
Class-Pro Stock GT
Date-6/28/2020
Race Time-4:38.657 (278.657)
Fastest Lap-3.486
Chassis-MR-03 EVO
Body-Ferrari 458 Italia GT2
Wheelbase-98mm
Tires-K30 radial fronts, K20 radial rears
Motor-Kyosho X-Speed (50T)
Batteries-TRP 747s
Front Springs-PN Purple
T-Plate-Kyosho CF Hard
Motor Mount-Kyosho stock plastic LM Pod
Dampener (If applicable)-Kyosho DDS
Gearing-Kyosho Ball Diff II with 6t pinion
Notes-This was only my second run for June, with no real changes to setup other than shimming spring on oil shock to adjust sagging, and my time was 12 seconds faster than the first run and 8 seconds faster than my May time. Only one 5.xx sec lap and four 4.xx sec laps, remaining 70 laps were 3.xx sec. Don't think I can do much better than that. I'll take it!
Date-6/28/2020
Fastest Lap-3.486
Chassis-MR-03 EVO
Wheelbase-98mm
Batteries-TRP 747s
#933
Class-Stock
Date-2020-06-26
Location-Phoenix, AZ
Race Time-462
Fastest Lap-5.100
Chassis-MR03
Body-Kyosho Sauber Mercedes C9
Wheelbase-102mm
Tires-Kyosho LM High Grip 20° fr/rr
Motor-PNR 70t
Batteries-Kyosho Speed House 800hv
Front Springs-mr03 stock
T-Plate-Kyosho carbon medium
Motor Mount-Kyosho MJ aluminum (LM)
Dampener (If applicable)-Kyosho Inner Tube Roll Shock
Dampener Fluid (If applicable)-Mineral Oil
Gearing-44t/8t
Notes- Not allowed to post photos yet....
Date-2020-06-26
Race Time-462
Fastest Lap-5.100
Chassis-MR03
Wheelbase-102mm
Motor-PNR 70t
Gearing-44t/8t
#934
If you are a member of the M96WC group on Facebook, you can post a picture of your car and results there if you’d like. You can also edit this and other prior posts in the future and add pictures once you have that permission.
#935
Class-Stock giugno 2020
Data-2020-06-30
Luogo-L'Aquila-Italia
Tempo di gara-285.6
Giro più veloce-3.64
Chassis-MR03
Corpo-Kyosho McLaren
Passo-98
Pneumatici-V8-20 anteriori V1-R10 posteriori
Motor -PNR 3500kw
Batterie-750mha
Molle anteriori-MR03 rosse
T-Plate-Pnr 3 fibra di vetro
Molle ammortizzatore centrale rosse
foto RISULTATI su FB
Data-2020-06-30
Tempo di gara-285.6
Chassis-MR03
Passo-98
Motor -PNR 3500kw
Batterie-750mha
#936
Class- Box Stock
Date- 6/30/20
Location- Denton, TX
Race Time- 356.3
Fastest Lap- 4.21
Chassis- MR03
Body- Audi R8 2010 LMS
Wheelbase- 98mm
Tires- Rear PN KS FR, Front Kyosho 20S
Motor- Stock
Batteries- EBL 800
Front Springs- PN Red
T-Plate- Kyosho Carbon Hard
Motor Mount- MM
Dampener (If applicable)- Stock
Dampener Fluid (If applicable)- N/A
Gearing- 7T Pinion
Notes- Tighter setup in the rear seams to let the car rotate more. Little bit of chatter I could never get rid of. Much improvement over May
Date- 6/30/20
Race Time- 356.3
Fastest Lap- 4.21
Chassis- MR03
Wheelbase- 98mm
Motor- Stock
Batteries- EBL 800
Motor Mount- MM
Gearing- 7T Pinion
#937
Box Stock June 2020
Class- Box Stock
Date- June 16, 2020
Location- Houston, Tx
Race Time- 374.9
Fastest Lap- 4.43
Chassis- MR-03 FHSS
Body- R8 LMS
Wheelbase- 98MM
Tires- Rear K10 Radials Front K20 slicks
Motor- Stock
Batteries- EBL 1100
Front Springs- Kyosho Yellow
T-Plate- PN-T2 Fiber Glass
Motor Mount- MM
Dampener (If applicable)- none
Dampener Fluid (If applicable)- none
Gearing- 7T
Notes- Will post screen shot on Facebook. Can't wait to post a picture on this forum.
Class- Box Stock
Date- June 16, 2020
Race Time- 374.9
Fastest Lap- 4.43
Chassis- MR-03 FHSS
Body- R8 LMS
Wheelbase- 98MM
Motor- Stock
Batteries- EBL 1100
Motor Mount- MM
Gearing- 7T
#938
Hello All,
Good to see some times get posted up.
Bear with me, it is absolutely bonkers at work currently and we are full-on getting our house ready to show.
I will try hard to get the July circuit posted up today but it may take a few days to get the results posted......
Bare with me and sorry about that.
Cheers,
Jim
Cheers,
Jim
#939
I was going to put in a time but forgot we were getting new washer and dryer yesterday and I had the track torn up. Oh well next month. I still need some parts in order to get into Box Stock class anyway.
No rush LJH, sorry to hear about your challenges but it sounds like the new house will be great!
#940
Hello All,
Bear with me and sorry about that.
Cheers,
Jim
Cheers,
Jim
Thanks for all you do! No hurry with the holiday weekend coming up. My guess is most of us our booked...
Anyone have recommendations on where to get wheels for the 90mm narrow stock class(mainly rears)? I plan to convert over one of my MM chassis to RM and use this body
I know I need 8.5mm with 0 offset, but I am not sure how to tell if the wheels will actually fit the drive dogs on the rears for certain.
Thanks!!
#941
Hello All,
Very light participation in June, but here are the results:
Box Stock-
3rd- Revto13G 374.9/4.43
2nd- FastJew- 356.3/4.21
1st- Traveler2- 315.2/3.75
Stock 90N
1st- Traveler2- 314.1/3.82
Stock
3rd- ekoorjr- 462.0/5.10
2nd- Traveler2- 291.3/3.54
1st- Medo998- 285.6/3.57
Pro-Stock
1st- Traveler2- 278.7/3.49
Open 2WD
None
FTM- Traveler2 278.7/3.49 in his Pro Stock Car.
Please let me know if I missed anyone or anything.
On behalf of our fearless leader, Jim, Cheers!
Box Stock-
Stock 90N
Stock
Pro-Stock
Open 2WD
None
#942
Thanks!!
Thanks!!
#943
#944
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Hello All,
Good to see some times for the month and a HUGE thanks to Traveler for getting the results published.
I wanted to get the July circuit posted for you guys.
It is a bit short and not terribly technical so I am expecting some fast times. For July we are running clockwise and on the smooth side.
Hello All,
3035Likes
