Mini-96 World Challenge >
Like Tree251Likes
Old 07-02-2020, 09:21 AM
  #946
Trader Rating: 15 (100%+)
Autoscales that come in the display case always come with wheels, hard tires and a display chassis if bought new. However in Japan and the R246 aftermarket line you can get finished bodies in more of a blister pack style packaging. Not sure if those are marketed still as "Autoscales" but those do not come with wheels and tires, just the finished body.
Also I should note with the autoscales, although the bodies are interchangeable regardless of chassis platform, the wheels it comes with will usually match how they're sold in ready sets. So if a certain body is normally sold with an AWD chassis ready set, it will have wheels that have the fitment for AWD and the offset of that respective chassis.
FastJew likes this.
soulstice is online now
Old 07-02-2020, 09:23 AM
  #947
NutDriver likes this.
Old 07-11-2020, 03:31 PM
  #948
You are correct sir! Came with the wheels shown and got it all setup last night. The 90mm narrow RM is a major change from the MM and LM wides I have been driving. Seems more at home on the tighter parts of the track, but tons of fun!
FastJew is offline
Old 07-12-2020, 06:34 AM
  #949
Nice! I love driving my 90mm RM 911 GT1 box stock car, but it is a wide front track and takes wide wheels in rear.
Traveler2 is offline
Old 07-16-2020, 08:17 PM
  #950
tomthegeek's Avatar
Class- Box Stock
Date- July 16, 2020
Location- Madison, Wi
Race Time- 333.67
Fastest Lap- 3.74s
Chassis- Kyosho MR-03
Body- Audi R8
Wheelbase- 98mm
Tires- PN Firm
Motor- White endbell MZ9P
Batteries- 800mah Nimah
Front Springs- Orange
T-Plate- Carbon Stiff
Motor Mount- MM2
Gearing- 6t w/stock diff
Notes-
Removed the disc damper and went back to the stock plastic gear diff so I'm legal for Box Stock. Had a pretty good run tonight despite the interference from the cat. On another note I may not have a place to use my Mini96 any more as I am apt hunting. Hopefully not my last entry in the challenge but it's possible.
The cat lap is pretty obvious lol
tomthegeek is offline
Old 07-28-2020, 12:25 AM
  #951
Default Risultati luglio 2020
Aula
Date 28-07-2020
Location Italia-L’Aquila
Race Time 248,7
Fastest Lap 3.10
Elettroniche kyosho
Body Mc
Wheelbase 98
Tris
Motor 3500
Batterie 750
anteriore Springs blu pn
T-Plate 2 nera
motore Il supporto della
antivibrazioni (se applicabile)
Dampener fluido (se applicabile)
Gearing- 9
Notes- allenato molto poco in questo mese estivo il modello comunque rimane difficile a causa dell’alta temperatura della pista foto crono su Facebook
Medo998 is offline
Old 07-29-2020, 09:12 PM
  #952
ekoorjr's Avatar
Default July 2020 Stock Results
Class-Stock
Date-2020-07-29
Location-Phoenix, AZ
Race Time-393.416
Fastest Lap-4.174
Chassis-MR03
Body-Kyosho Sauber Mercedes C9
Wheelbase-102mm
Tires-Kyosho LM High Grip 20° fr/rr
Motor-PNR 70t
Batteries-Kyosho Speed House 800hv
Front Springs-PNR Yellow
T-Plate-Kyosho carbon Hard
Motor Mount-Kyosho MJ aluminum (LM)
Dampener (If applicable)-Route246 Roll damper/oil shock
Dampener Fluid (If applicable)-Mineral Oil
Gearing-PNR 52t/12p
Notes-Rear end slips on fast turns - thinking about trying harder fronts
Added PNR double A-arm front suspension since last month
File Type: pdf
ekoorjr is offline
Old 07-29-2020, 09:14 PM
  #953
ekoorjr's Avatar
Default July 2020 Open2wd
Class-Open2WD
Date-2020-07-20
Race Time-393.959
Fastest Lap-4.162
Chassis-GLRWD
Body-SubRC
Wheelbase-98mm
Tires-PNmedFR,PNssR
Motor-GL5500kV
Batteries-GL330MaH LIPO
Front Springs-GLRWD stock
T-Plate-n/a
Motor Mount-GLRWD stock
Dampener (If applicable)-Stock GLR tri-damper
Dampener Fluid (If applicable)-Kyosho Ball Diff #30000
Gearing-52t/13p
Notes-Figured out how to tone down the throttle so now this car is loads of fun on the Mini-96
File Type: pdf
ekoorjr is offline
Old 07-31-2020, 06:36 PM
  #954
Default Box Stock
Class- Box Stock
Date- 7/30/20
Location- Denton, TX
Race Time- 309.9
Fastest Lap- 3.67
Chassis- MR03
Body- Audi R8 2010 LMS
Wheelbase- 98mm
Tires- Rear PN KS MR, Front PN KSM SS
Motor- Stock
Batteries- EBL 800
Front Springs- PN Red
T-Plate- Kyosho Carbon Soft
Motor Mount- MM
Dampener (If applicable)- Stock
Dampener Fluid (If applicable)- N/A
Gearing- 7T Pinion
Notes- This car feels like a tank after driving the Stock 90MM Narrow. Car runs well I am just not as consistent with it.
FastJew is offline
Old 07-31-2020, 06:37 PM
  #955
Default Stock Narrow
Class- Stock 86/90MM Narrow
Date- 7/30/20
Race Time- 315.2
Fastest Lap- 3.71
Chassis- MR03
Body- Initial D Mazda Savanna RX-7 FC3S
Wheelbase- 90mm
Tires- Rear Kyosho 30R 8mm, Front Kyosho 30S 8mm
Motor- Stock
Batteries- EBL 800
T-Plate- PN #4 Carbon
Motor Mount- RM
Gearing- 7T Pinion
Notes- Enjoying this car the most. Feels right sized for this track. Have to be very mindful of speed though as it rolls easily.
FastJew is offline
Old 07-31-2020, 06:38 PM
  #956
Default Stock
Class- Stock
Date- 7/30/20
Race Time- 300.8
Fastest Lap- 3.42
Chassis- MR03
Body- Mazda 787B
Wheelbase- 102mm
Tires- Front Stock, Rear Stock
Motor- Stock
Batteries- EBL 800
Front Springs- PN Purple
T-Plate- PN #5 Carbon
Motor Mount- LM
Gearing- 6T Pinion
Notes- Needs tires, but with just some stiffer suspension it runs pretty well.
LJH likes this.
FastJew is offline
Old 08-01-2020, 11:19 AM
  #957
LJH
Default August 2020 Circuit
Hello All,
good to see some activity. I have to say I am looking forward to getting back on track
With that said here is the circuit for August. It is the same as July but run counter clockwise.
I will try and get the results posted tomorrow.
Full Send.
tomthegeek likes this.
LJH is offline
