SERPENT MALAYSIA - News, Support & Discussion Centre
#481
#482
#484
shu sebenarnya tunggu aku slow sikit lagi baru dia main balik...
#486
Laju laju nak gi mano wei……….
"Speed gets you nowhere if you're headed in the wrong direction."
"When the flag drops, the bullshit stops."
"Once your car seems slow; you are going fast"
#487
Attachment 595050
The position of the roll axis relative to the cars CG tells a lot about the cornering power of the car; it predicts how the car will react when taking a turn. If the roll axis is angled down towards the front, the front will roll deeper into its suspension travel than the rear, giving the car a 'nose down' attitude in the corner. Because the rear roll moment is small relative to the front, the rear won't roll very far; hence the chassis will stay close to ride height. Note that with a car with very little negative suspension travel (droop) the chassis will drop more efficiently when the car leans over. With the nose of the car low and the back up high, a bigger percentage of the cars weight will be supported by the front tires, more tire pressure means more grip, so the car will have a lot of grip in the front, making it oversteer. A roll axis that is angled down towards the rear will promote understeer. Remember that the position of the roll centers is a dynamic condition , so the roll axis can actually tilt when the car goes through bumps or takes a corner, so it's possible for a car to understeer when entering the corner, when chassis roll is less pronounced, and oversteer in the middle of the corner because the front RC has dropped down a lot. This example illustrates how roll center characteristics can be used to tune a car to meet specific handling requests, from either the driver or the track.
#490
#492
#493
nak tanye ckit, kalu pakai spool depan, teknikel trek ok ker.. ?
#494
#495
