Tamiya TA07 pro
#706
I refuse to race one color paint jobs. Unless done very well with appropriate decals as well, one color paint looks lazy. Anyone can add racing strips at least.
Yes I airbrush mine myself. The paint is minimal to get that kind of work. I know it's a bit heavy due to the shoe goo front end, but that is a necessary evil for a 2 piece or pretty much any VTA body.
Thanks for the input.
I have a couple bodies with spoilers Shoe-Gooed in place, but I use a tiny dab of the stuff on each contact point and I use neodymium magnets to squeeze the parts together as the Shoe-Goo sets. That way I need so little of the stuff that its weight is undetectable.
Remember, the people who win are the people who will make all necessary compromises, whether it's spending hours running practice laps, using annoying glass tape instead of a convenient tie-down bar, or using a "lazy" single-piece body.
#709
Droop.
Managed to mess up my settings (which were per the manual). What number should I be aiming for on a droop gauge with the car sat on droop blocks please. I've set it to 3 all round at the moment but haven't run it yet. We run on grey carpet (primafelt?). Stock rear and C blocks up front.
#710
I run Grey carpet as well and I'm at 2.5 front 2 rear. Initially I was going for more drop (lower number) but the tub chassis won't allow it. However, it turns out the car doesn't need it. At least in VTA.
Car drove great right out of the box. I have 05e blocks up front though.
#711
Thanks. Now I'm just wondering how to shave 40ish grams from the car. I have already put all the lightweight components on the car that I can. Aluminum screws, diff outdrives, axles, etc. even running a pretty light weight ESC. Anyone (other than Bert) have any suggestions?
Other then a low pro battery.. My Orca 75C 6000mah weighs 20-30 grams less then my full size Orca 100C.. Just throwing that out there. The extra power from the bigger packs may out due the lightness in a sense though.
I need to see a ta07 in person to get some more ideas. What are you at now 1480-1500 grams? I hear you on the shoe goo and reinforcement.. It's needed but there is at least 10-15 grams usually added to the body when we do that.
#713
T works! That's the company. Don't see any Tamiya though :/
https://www.rc-tworks.com/collection...ay-yokomo-2pcs
#714
Only just noticed that. Not sure if it's a prototype part they left on for the manual photo or a forthcoming release. Would have thought the latter unlikely as the kit plate is already a) aluminium and b) anodised blue. Traditionally Tamiya Hop-Ups usually replace the dull grey alu or plastic parts, can't recall a blue bit being replaced by another blue bit. Also that cut-out plate looks fugly although so does the Hop-Up servo mount (I still bought one) compared to the beautiful TRF417v5 one that they showed in the initial Show photos.
#715
#717
When summer parking lot racing comes back around, though, I'll put it back on.
#718
Got my Techra Suspension mounts and Axion spur gears today. Can't wait to install them.
Edit,
FYI,
In order to get the Techra suspension mount to fit in the rear, you will need to shave some plastic down on the rear lip of the chassis. If you need pictures let me know, I can show you.
Edit,
FYI,
#719
alum axles1
www.exotekracing.com
They have alum axles that fit most of the Tamiya chassis!
