Like Tree488Likes
Tamiya TA07 pro
Old 01-25-2022, 07:37 PM
  #2536
OVA
OVA's Avatar
Trader Rating: 87 (100%+)
maybe this should be close set up
Tamiya TA07Pro - Mark Santa-Ines - TCS - Tamiya America - 27.08.2017 (petitrc.com)
OVA is offline
Old 09-10-2022, 09:41 AM
  #2537
YFB
Time to bring this TA07 thread alive again. Built the F77 Exotek TA07 FWD Conversion using the latest TA07 & TRF420 parts. Although the FF77 is now discontinued, it's still an awesome beautiful piece of kit especially spec with the best parts (lots of blue Tamiya goodness). I chose Exotek knowing they make quality stuff that i've used before. And I wanted to keep my TA07 intact as its been properly setup, that's why I also chose to build from parts.
I've seen other brands like PSM and H2RD with other Tamiya FWD / FF conversions that you could try if keen.
This could be passed off as a TRF420F or an FF05 Evo. Come on Tamiya, build us one like this!
Enjoy the video.
YFB is offline
Old 09-10-2022, 09:44 AM
  #2538
YFB
Some more pics of the build from the vid.
BuggyFan21 likes this.
YFB is offline
Old 11-05-2022, 05:24 PM
  #2539
h2e
h2e's Avatar
Managed to get my TA07 with the RClabHK chassis running fine on super high grip carpet today. Gone are the days of oversteer. This car is a tank, if you are using the new TRF420 C hubs.
Finally ir's my casual racer again: put the battery, clean tyres and go.
Yes this is still a TA07 at heart...
dmcguire, gwhiz and jgil089 like this.
h2e is offline
Old 11-25-2023, 03:45 AM
  #2540
Anyone selling the following parts?
Front Carbon Fiber Stiffener - 54788
Rear Carbon Fiber Stiffener - 54789
Carbon Reinforced chassis - 54745
jessele is offline
Old 03-20-2024, 10:45 PM
  #2541
lbckevin's Avatar
Trader Rating: 107 (99%+)
try Plaza Japan, they have alot of parts.
lbckevin is offline
Old 03-21-2024, 11:02 AM
  #2542
IndyRC_Racer's Avatar
Tamiya often refers to the chassis as a "lower deck". I did a quick search (TA07 lower deck) and found several chassis for sale, but they were all too expensive.
IndyRC_Racer is offline
Old 05-02-2024, 05:25 AM
  #2543
Anybody know of other brand shock springs that fit the standard Big Bore shocks? seems like they are 14 mm inside diameter. And 25 mm long
Thanks in advance.
Al Sodano is offline
Old 05-02-2024, 06:12 AM
  #2544
dmcguire's Avatar
Trader Rating: 38 (100%+)
I use my old Corally RDX springs. Not sure you can find them anymore, but fit right.
dmcguire is offline
Old 05-08-2024, 06:07 PM
  #2545
Trader Rating: 24 (100%+)
For the super short big bore shocks, I think xray springs work. Has anyone deciphered the hinge pin puck system to determine caster and camber setup? I could use a tutorial on how to setup for 4 degrees caster and 3 degrees toe for the rear.
vinny73 is offline
Old 05-14-2024, 10:55 AM
  #2546
Thanks in advance.
When not racing TCS I use wither SMJ or older xray.
GregAnthony is offline
Old 05-25-2024, 02:06 AM
  #2547
Anyone have a set of Exotek bulkheads for sale?
jessele is offline
