Tamiya TA07 pro
#557
For those who are interested in some numbers about weight saving, check below :-)
Standard 44mm steel swing shafts : 9,1gr (per set)
Aluminium 44mm swing shafts : 3,6gr (per set)
Standard TA07 geardiff outdrives : 11,0gr (per set)
TRF419 Aluminium geardiff outdrives : 3,9gr (per set including swing shaft protectors)
Standard metal 850 bearing (part nr BB12) that goes into the geardiff : 1,0gr (per set)
850 Ball bearing : 0,7gr (per set)
I've also changed the steel screws on top of the chassis to aluminium screws and this gave me a weightsaving of 13gr.
Gave me a total weight saving of 26gr :-)
#558
The front spool (or Direct Coupling) for the TA07. Is there a lighter option for the spool cups?
#559
Very nice! Do you know what the spool weighs? what about the diff?
#568
Trader Rating: 89 (100%+)
oneway
I can still hear it " I got one wayed man!"
#570
TA07 reminds me so much of my Losi XXXs.
