VBC Lightning FX >
VBC Lightning FX
Like Tree142Likes
VBC Lightning FX
Old 09-27-2015, 02:09 PM
  #16
skyball's Avatar
Originally Posted by AlexPate
I have found that using an upper pivot ball from a lightning pan car fits the shock eye snugly, all you need is .3mm shims to center the ball in te shock mount.
Part number is
B-02-Vbc-5068
Thanks for the hint, ordered some...
Christian
skyball is offline
Old 09-28-2015, 05:57 AM
  #17
Trader Rating: 41 (100%+)
Nice that they went back to a good design. the Flash04 was a way better car
jdeadman is offline
Old 09-28-2015, 09:29 AM
  #18
Regional Moderator
disaster999's Avatar
Sucks that body options are limited and cant run any of the more realistic bodies, but if this car doesnt push as bad as the old lightningf, I can get over it.
disaster999 is offline
Old 09-29-2015, 09:22 PM
  #19
what specific bodies won't fit on the LightningF? something like the Tamiya MP4-24? will they fit needing modification? i am about to drop $$ for this one... i'm between the Serpent SF2 and this at the moment.
voodoo is offline
Old 09-30-2015, 08:04 AM
  #20
Suspended
What body(s) do fit this car? Looking to possibly build one
Mysterious is offline
Old 10-01-2015, 03:23 AM
  #21
skyball's Avatar
...many bodies are not wide enough at the rear to fit. I have a Protofom F1-Thirteen that fits though.
Christian
skyball is offline
Old 10-02-2015, 02:37 AM
  #22
skyball's Avatar
Just found that my Yokomo high nose body (YOK-YF-01HN) fits too...
skyball is offline
Old 10-05-2015, 08:59 AM
  #23
celt's Avatar
Default ride height
Anyone know if standard Tamiya or Tuning Haus rear ride height insert work n the rear bulkheads?
celt is offline
Old 10-05-2015, 03:21 PM
  #24
VBC bearing/ride height inserts are unfortunately not compatible with Tamiya or Tuning Haus inserts.
Bill Jeric is offline
Old 10-08-2015, 03:38 PM
  #25
AlexPate's Avatar
Trader Rating: 19 (100%+)
ran the car for the first time using kit setup, as the grip started coming up it felt as if the front was rolling over a little too much so some stiffer springs will most likely be in order. it was a good day, took a big hit to a click track pipe and nothing broke, tq, win and fast lap, cant wait to try the car at my home track!!
AlexPate is offline
Old 10-11-2015, 05:26 AM
  #26
what size pinion you use for a 21.5 moter
ScottZ is offline
Old 10-15-2015, 07:28 PM
  #27
dr_hfuhuhurr's Avatar
Trader Rating: 95 (100%+)
How are you all getting the battery in and out? For safety reasons I won't charge the battery in the car.
dr_hfuhuhurr is offline
Old 10-15-2015, 07:59 PM
  #28
AlexPate's Avatar
Buy an orca 4800 hv
Never puffs... But seriously you will probably have to remove the front shock mount plate
AlexPate is offline
Old 10-15-2015, 09:20 PM
  #29
Regional Moderator
That sucks, I would think they would design the chassis so you dont need to remove anything to take out the battery. It sucked with the old LightningF, removing 4 screws every time I need to swap out the battery or just for a charge since the top plate covers up the balance port.
Old 10-15-2015, 09:35 PM
  #30
AlexPate's Avatar
Design usually follows the path of speed vs ease of changing the battery, that being said I never take the batt out of my f1, in my Lightning f I ran battery forward with the bullets at the back then I made a short jumper wire for the balance port, a 2mm bullet on one side and. 4mm bullet on the other side. The 4mm bullet acted as a receptacle for the balance wire from your charger.
AlexPate is offline
