VBC Lightning FX >
VBC Lightning FX
Like Tree142Likes
VBC Lightning FX
Old 09-14-2015, 10:05 AM
AlexPate's Avatar
Trader Rating: 19 (100%+)
Default VBC Lightning FX
The NEW VBC Lightning FX is officially released, coming to or at a store near you
AlexPate is offline
Old 09-15-2015, 07:40 PM
Great Car!
Yokolun is offline
Old 09-16-2015, 07:36 AM
dr_hfuhuhurr's Avatar
Trader Rating: 95 (100%+)
In the process of building mine. First time with a F1...SUCH a nice kit. What's the preferred body/wing setup for carpet/rubber tire?
dr_hfuhuhurr is offline
Old 09-17-2015, 07:19 AM
AlexPate's Avatar
Everything you need right here. http://gripworksrc.com/collections/formula-1
F60 front wing, Fthirteen protoform body, 3 racing rear wing very durable, pits 571,572 tires, tcs 1031,1032 tires or the new Crc rubber.
And maybe just go with kit setup to start as there is enough new parts that a lightning f setup won't transfer over directly
AlexPate is offline
Old 09-17-2015, 10:51 AM
skyball's Avatar
Default Transfer from Lightning F thread
Hi everyone,
we had a little discussion on the new Lightning FX over in the old Lightning F thread. To avoid further confusion I proposed there to continue our discussion regarding the FX here, where it belongs.
The interesting bits from the other thread up to now:
Yokolun posted a first picture and a video link:
Originally Posted by Yokolun
My Lightning FX Testing in Hong Kong
+ YouTube Video
I asked for a base setup and he answered:
car quite good for ETS because it is easy to drive,
i just change the wheel base to 264mm
Side Spring i try the Associated 3.75lb to 5.00lb
Low Traction i will choose 3.75lb
Normal or High i will try 5.00lb or 6.25lb
Otherwise, Yokomo Side Spring also work for Lightning F/ Lightning FX
Front Spring i use Ride Soft, Front wing i use the Serpent with High Downforce Setup
Rear Wing i use TRG one, High Traction maybe i will try Serpent rear wing
you may collect more rear wing and front wing and Shell for Testing
After building my car I had more questions ...
Originally Posted by skyball
Thanks a lot for your advice, I will try as soon as I can get on track.
BTW, I just built my car today and found everything fitting very nicely. My only concern is with the front attachment of the shock. The eylet is a little too wide for the ball cup, so there's some play (more, than I like). Can you confirm that, and did you find a workaround?
Another question: the kit setup states a overall shock length of 64.6 mm. If I measure that between the centers of the shock eyelets (which is the usual way IMHO), then the shock would get much too long. If I measure it from end to end (including the eylets plus their rim), then I get a reasonable shock length allowing for just a little droop. How do you measure shock length, and what's you're actual setting?
Greets, Christian
In reply AlexPate recommended:
Originally Posted by AlexPate
I would base the shock length on pod droop. Usually around 1.5mm is what you want. Just adjust the overall length untill your desired pod droop is acheived
So far so good,
Christian
skyball is offline
Old 09-18-2015, 01:45 AM
skyball's Avatar
...anybody else experiencing this? Ideas, workarounds?
skyball is offline
Old 09-18-2015, 04:08 AM
I had the original Flash F1 car from them. Plastics were to soft and stripped out (front upper arms) and so was the aluminum. I did a lot of work to fix the problems brought about by poor materials design. I hope this car is better but I will stick with my CRC WTF1.
old_dude is offline
Old 09-18-2015, 10:14 AM
AlexPate's Avatar
Vbc plastics a have come along way since back then.
The Lightning f has been virtually indestructible. The only time I ever broke mine was when it really deserved it.
AlexPate is offline
Old 09-18-2015, 10:15 AM
AlexPate's Avatar
I don't have mine yet so I can't confirm what you are experiencing. What about putting o-rings on either side of the ball cup inside the mount?
AlexPate is offline
Old 09-18-2015, 01:14 PM
angrymelon's Avatar
Another hack you can do is to take the clear plastic that parts come in, and pinch it between the ball and cup and trim the excess. It still allows the ball to move freely, and helps reduce the slop.
angrymelon is offline
Old 09-21-2015, 02:51 PM
AlexPate's Avatar
Kits should be arriving stateside in 1-2 weeks.
AlexPate is offline
Old 09-25-2015, 12:38 AM
skyball's Avatar
My only concern is with the front attachment of the shock. The eyelet is a little too wide for the ball cup, so there's some play (more, than I like).
So here is my solution for the moment.
Used parts:
1 aluminum spacer 3 x 5.5 x 3 mm
2 plastic washers 3 x 6 x 1 mm
I pushed the aluminum spacer into the shock eylet, where it sits just right. Then I attached the shock to the mount and slid one of the plastic washers onto the screw on either side of the shock eyelet.
This way the shock sits centered, without slop. Take care not to overtighten the screw, otherwise the shock will bind.
EDIT: I DON'T RECOMMENDED THIS ANYMORE AS IT ONLY ALLOWS FOR VERTICAL ACTION OF THE SHOCK, BUT LATERAL ACTION IS ALSO NEEDED WHEN THE POD TILTS.
Christian
Attached Thumbnails VBC Lightning FX-lfx-shock-parts.jpg   VBC Lightning FX-lfx-shock-assembled.jpg
skyball is offline
Old 09-25-2015, 06:49 AM
You could use something like the kingpin shims. That should work.
Old 09-25-2015, 08:26 AM
skyball's Avatar
Thanks for your suggestion, but I found an old 3racing eyelet in my box, that fits tighter on the original ball. So I'm fine now.
Christian
skyball is offline
Old 09-27-2015, 12:28 AM
AlexPate's Avatar
Used parts:
Christian
I have found that using an upper pivot ball from a lightning pan car fits the shock eye snugly, all you need is .3mm shims to center the ball in te shock mount.
Part number is
B-02-Vbc-5068
They also sell shim sets I think.
AlexPate is offline
