World GT-R Rules and Discussion >
Like Tree849Likes
Old 09-05-2018, 05:02 AM
  #1486
Originally Posted by redmonster27
Yeah I have one but it tends to leak alot when the car is sitting between race weekends
Always remember, the Fenix isn't a diff made for fluid. It is a grease diff only. The new Xray diff is a fluid diff. I have run the Fenix, Ball and a spool in my CRC car. I will soon try the Xray. Of the first three I usually prefer the ball diff because of a combo of weight and handling. The spool is also good but a high bite track but a small mistake on the rubber tires can cause a problem. The Fenix with grease is always good but its extra weight just hurts a little on tight tracks.
With that said they each have their place.
old_dude is offline
Old 09-05-2018, 11:06 AM
  #1487
redmonster27's Avatar
Trader Rating: 34 (100%+)
I'm running 2.5mill in the diff and I'll be trying 20mill tomorrow don't get me wrong I like the diff was just wondering if the xray diff would work. To cut down on the leakage thanks
redmonster27 is offline
Old 09-05-2018, 03:30 PM
  #1488
I run the xray diff on my 1/12th CRC with no problem. I would rather have the Fennix but they don't make the gear small enough.. The Vette body I run it medium all the way around with no problem- either one. I like the newer vette better-as I knock off 1/10th over the older one but that could just be me.
BullFrog is offline
Old 09-06-2018, 04:34 AM
  #1489
Do the sidewalls stick out? If they do then according to the class rules it isn't legal. That is a generally not enforced rule. I ran the MX Stang on the medium setup for quite awhile until Dumper informed me that I wasn't running it in line with that rule.
I have both vetts from PF. The ZR-1 is much better on black carpet.
old_dude is offline
Old 09-06-2018, 07:20 AM
  #1490
Never had a problem in tech with the older vette.Your right about the MXStag.
BullFrog is offline
Old 09-11-2018, 11:56 AM
  #1491
Hey guys,
Just curious to see everyone's thoughts, when setting up a WGT car and going from the foam tires to the rubber tires, what setup changes did you make to your baseline setups? Stiffer springs and heavier oils all around? Less camber and gluing the outside edges of the tires? Stiffer center shock to handle the increased weight?
lowdoughracer is offline
Old 09-12-2018, 04:44 AM
  #1492
Originally Posted by lowdoughracer
Hey guys,
Actually we set the cars up softer. Soft front springs with 1-2 mm of droop, Soft side springs on the rear. The center spring is usually a medium rate with some rear droop. Oil in the center is similar to a foam setup. Front caster and camber aren't much different. Sidewall glue as track dictates.
old_dude is offline
Old 10-01-2018, 08:55 AM
  #1493
The minimum body weight of 95 grams has been updated.
dumper is offline
Old 10-04-2018, 05:25 AM
  #1494
Will the new Ford Gt #1550-25 be added to the list?
Friulimotosport is offline
Old 10-04-2018, 10:06 AM
  #1495
YoDog's Avatar
Trader Rating: 28 (100%+)
Isn't that the 190mm version?
The 200mm is already legal for this class. The 190mm was created for USGT.
YoDog is offline
Old 10-04-2018, 10:20 AM
  #1496
Just asking as there are other 190mm bodies on the list.
Old 10-04-2018, 01:12 PM
  #1497
Dumper, will this be enforced at this years IIC? Also, will anything such as Shoe Goo for re-enforcement< within reason, say around the front wheel wells or the splitter in the front be allowed?
I was wondering the same thing.
team_tamale is offline
Old 10-05-2018, 08:05 PM
  #1498
f1larry's Avatar
Trader Rating: 22 (100%+)
What is a good starting point for gearing?
f1larry is offline
Old 10-06-2018, 03:58 AM
  #1499
Motor and track dependent.
old_dude is offline
Old 10-06-2018, 06:53 PM
  #1500
XSRCdesign's Avatar
Bodies must weigh a minimum of 95 grams with the weight comprised of the body (all pieces and wings etc), paint and stickers. No pieces of weight will be allowed to assist in making the 95 gram minimum.
is shoe goo/ reinforcement tape considered pieces of weight?
Just curious since there are a few “approved” bodies on this list that fall under this weight, even painted and stickerd up.
XSRCdesign is offline
