Xray X1 - Formula One Car >
Like Tree305Likes
Old 01-04-2018, 01:33 AM
  #2341
Nuno Gancho's Avatar
Hello need your support.
Running outdoor and due to cold weather and no grip on the track my car only works for one lap then the rear has no grip and keeps spinning when I push throttle, can’t change tyre only have Ride R1 front and rear, any suggestion running 21.5 without boost or turbo, F1 2016, basic asphalt settings with Montec wings and protoform F15 body.
Meantime what will be the difference on center shock with or without rebound.
Nuno Gancho is offline
Old 01-04-2018, 05:11 AM
  #2342
g12314's Avatar
Originally Posted by Giorgio
New parts from Fenix Racing
For the popular Xray X1, the "oring" battery holder is now ready.
Forget the annoying tape, an easy to use oring holder is available from now.
Best of all, will not induce any unwanted tweak on the main chassis, leaving the chassis free to twist.
Hopefully we will see this in the US at some point along with the light weight front axels. Waiting patiently .
g12314 is offline
Old 01-04-2018, 10:16 AM
  #2343
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Giorgio, any update on the carbon shaft for the Fenix gear diff?
Love your products. Running a Fenix gear diff and Fenix chassis on my X1.
Dan is offline
Old 01-04-2018, 10:41 AM
  #2344
Sorry for the crappy pic. I’ve been using this setup with 2 elastic bands from the rear brace to a ball stud under the body post. It’s across the widest part of the chassis so there should be minimal effect on the flex. Plus it’s the aluminum chassis.
viking44 is offline
Old 01-05-2018, 01:32 PM
  #2345
MD
MD's Avatar
Trader Rating: 136 (100%+)
Does anyone use the Fenix gear diff and what grease do you use?
MD is offline
Old 01-05-2018, 11:30 PM
  #2346
Hello what have less front down force xray front wing with low down force spoiler or montek front wing without flaps
Old 01-06-2018, 07:07 AM
  #2347
Giorgio's Avatar
Check in CRC for the front axles.
Some were sent in with the last shipment.
Giorgio is offline
Old 01-06-2018, 08:12 AM
  #2348
kilohertz's Avatar
I downloaded Jan R's sheet for 2016 Snowbird Nationals (indoor CRC Carpet) and completely rebuilt my 2016 car based on all of the shims, spacers and springs etc...put it on the setup board last night and the front end is only 1.5mm - 2mm or so off the ground, rear about 2.5mm. As this is my first foray into F1, I'm not sure which spacers to adjust to get to 3.5-4mm, while keeping the intended suspension geometry and roll centers etc. The rear I think is just a matter of changing the offset axle mounts (eccentric bushings). I am assuming that there are different diameter tires for F1, which is probably why my car is so low.
Do I remove spacers from under the upper arm posts, lower posts,(maybe 2mm instead of 4mm) or adjust the axle hub shims? I also don't have any droop right now...maybe that is the intention.
Any help would be greatly appreciated.
Cheers
PS is there supposed to be a fixed number of shims on the king pin? ie total of 7, and then adjust ride height by varying the above/below qty, but always keeping the same total amount?
kilohertz is offline
Old 01-06-2018, 09:04 AM
  #2349
KE4PJO's Avatar
Cheers
Here's a helpful tool..Team Xray X1'16 - Setup Helper
freebird likes this.
KE4PJO is offline
Old 01-07-2018, 11:06 AM
  #2350
kilohertz's Avatar
Default Gravity RC side springs
Could anybody tell me what the spring rates are for the 5 different coloured side springs made by Gravity RC, or tell me how they compare to the Xray springs? I only have the goldy coloured silver Xray springs which seem to be the stiffer of the 2 silver springs, but I have multiple sets of GRC all 5 colours. I've searched the web but can only find , soft, medium, firm etc which doesn't really say much.
Any help, again would be wonderful.
Cheers
PS On Jan's 2016 'bird sheet side springs are indicated as "SILVER" anyone know if these are the stiff silver or the soft silver?? Couldn't Xray have used more than 3 colours?
Old 01-08-2018, 12:05 PM
  #2351
Giorgio's Avatar
Depends from the surface, on carpet you might want to start with a 500K
But you may want to have a look at the setting videos
https://www.youtube.com/channel/UCDZ...2EaI7qHCMjUcjQ
As usual, comments are welcome
Giorgio is offline
Old 01-08-2018, 12:31 PM
  #2352
Dan
Dan's Avatar
I like switching between 100k and 300k depending on traction and track layout. Most setups I see go a little heavier but it didn't work well for me.
Dan is offline
Old 01-08-2018, 12:50 PM
  #2353
MD
MD's Avatar
Thanks, that helps.
Giorgio, I am going to send you a PM about something else.
MD is offline
Old 01-12-2018, 11:39 AM
  #2354
kilohertz's Avatar
Default Shock mount extension, my version
Had a little time today so I opened up my son's Meccano set and started fabricating some chassis stiffeners, and then decided to extend the shock mount. Pics show the results. Track time this Sunday will see if it's better/worse. Easy to mod the shock position with the extra holes. My servo is mounted the standard way with the posts attached to the chassis, I used the floating mount inverted and then added the Meccano piece to join the original shock location to the carbon floating servo mount, spacing worked perfectly, no drilling or modding required. Used a 4mm plastic bushing/spacer that fit right inside the shock spring holder to keep it centered, threaded the T4 standoffs together and everything fit perfectly. Needed one 4mm spacer at the end of the standoffs to get a little more droop, looks good on the workbench, we'll see Sunday.
Cheers
Attached Thumbnails Xray X1 - Formula One Car-img_4263.jpg   Xray X1 - Formula One Car-img_4265.jpg
Old 01-12-2018, 04:15 PM
  #2355
R/C Tech Elite Member
JayL's Avatar
Cheers
Meccano?
JayL is offline
